Results 1 to 5 of 5
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Default ER chucks for 260/9" Hercus
    Anyone who may be interested in these please note the the accuracy on your machine can not be guaranteed and you may need to re cut the 8 degree collet taper, machining allowance for this has been allowed for if required.
    Sent from my T85 using Tapatalk
    Nov 2007
    melbourne australia
    3,228
    I bought one of Peter's ER40 collet chucks for my Hercus 260. It had 0.1mm of runout which was easily removed by taking a skim cut with a HSS boring bar. I set the compound to the correct angle by running a DTI along the inside of the chuck and adjusting the angle until the DTI showed no movement. I confirmed the compound setting by turning a piece of stock to 8mm to ensure concentricity, slipping an 8mm collet onto it and checking with a DI.
    I'm very happy with the chuck. I no longer have any limitation on stock length and no more stuffing around with a draw bar.
    Oct 2011
    Sydney, NSW
    1,249
    Hi,
    I bought one of Pipeclays ER32 chucks a couple of months ago for my 260ATM. I've used it a few times now and it works great. Just letting Pete know.
    Ben.
    Aug 2019
    Revesby - Sydney Australia
    56
    1,183
    They look great!
    Do you also make a pin spanner for tightening the ER nut against the chuck?
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Just use the collet spanner, you can make a purpose pin spanner,but the collet spanner works fine.
    You may find that a 2nd spanner is beneficial as you can hold the chuck with one whilst you release the nut.
  1. QLD New old stock Pratt Burnerd outside jaws for 4" 3 jaw chucks.
    By lamestllama in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 23rd Nov 2021, 08:48 AM
  2. Hercus Collet Chucks 260
    By pipeclay in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 3rd Aug 2018, 05:35 PM
  3. Hercus "O" mill.
    By stix012 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 24th Oct 2017, 07:42 PM
  4. Ex Hercus "Asia Planer"
    By rickw72 in forum THE HERCUS AREA
    Last Post: 22nd Apr 2014, 06:34 PM
  5. WEST AUST Hercus metal lathe 12" x 42" excellent condition
    By craig manley in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 6th Jul 2011, 02:29 AM
