Results 1 to 5 of 5
17th Dec 2018, 09:59 PM #1Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
Steel plate suit small welding bench, SA
The clean out continues.
I have a 30mm steel plate that measures 810x860. It has a welded on 20mm flange around the edge and through the centre that is tapped M12x1.75 and is 100mm in height. The surface of the plate has been machined flat as has the flange. Weighs around 200kg.
This was the bottom half of a large milling machine fixture and had another larger ground flat plate attached to the web. I have removed the larger plate and used it as part of a fixture table (because who doesn’t need a fixturing surface that weighs 700kg ).
Its been sitting outside for a bit so it will need a bit of elbow grease invested to bring it back from the surface rust on it.
Ideal for a flat welding surface, I had intended to turn it into one but I don’t currently have room.
Priced at $125 FIRM (it’s not scrap price, but not far off it).
Pick up from either Salisbury or Golden Grove areas in Adelaide (or I can deliver within 50km of Adelaide CBD at fuel cost plus a sixer). If you’re interstate and keen, I’m willing to help with freight, message to discuss options.
17th Dec 2018, 10:01 PM #2Most Valued Member
- Mar 2011
- 1,552
Oops, forgot to mention, the pictures show two, one has already been sold.
22nd Jul 2019, 02:30 PM #3New Member
- Mar 2014
- 1
Aware this was a while ago - did you end up selling the steel plate? or do you still have it?
23rd Jul 2019, 06:39 AM #4Most Valued Member
- Mar 2011
- 1,552
I still have it, send me a PM if you are interested
23rd Aug 2019, 02:01 PM #5Most Valued Member
- Mar 2011
- 1,552
All sold
Both plates have now been sold
Small surface plate bench
By BobL in forum METALWORK GENERALReplies: 14Last Post: 31st Oct 2018, 03:25 PM -
wanted Chuck backing plate to suit Lantaine 350/ McMillan 2inch x 8TPI
By kjbs in forum WANTED TO BUYReplies: 0Last Post: 26th Apr 2018, 05:01 AM -
Flattening 16mm steel plate for a welding table
By OxxAndBert in forum METALWORK GENERALReplies: 7Last Post: 8th Jan 2018, 07:30 PM -
Steel plate for welding table
By th62 in forum WELDINGReplies: 6Last Post: 18th Aug 2014, 09:18 AM -
Advice on welding thin steel plate
By Sterob in forum WELDINGReplies: 24Last Post: 31st Jul 2012, 06:57 PM
