Results 1 to 13 of 13
Thread: Lathe Western Austrailie
15th Nov 2018, 01:23 AM #1Golden Member
- May 2003
- 526
I have a Hare and Forbes AL336D lathe in as new condition up for sale for $3k. It has a a fair bit of tooling including carbide inserts as well as all the accessories that came with the lathe.
Do a search here to get more details.
I will also give some solid bar stock to play around with.
Will have to be picked up from Alexander Heights and I can help with loading on a trailer or ute and can lend you the same equipemt to unload at your end.
Send me a PM and I will forward my details.
If anyone is interested in solid or hollow round steel stock I have a fair bit up to large diameter at various lengths available at $1.00 kg pick up only.Cheers,
Rod
15th Nov 2018, 01:07 PM #2Golden Member
- May 2003
- 526
Somebody has requested photos of the steel.
What is left is scattered around the shed and much more than can be seen in the photos.
I.m not a good photographer so use the imagination.Cheers,
Rod
15th Nov 2018, 02:04 PM #3Member: Blue and white apron brigade
Good to see you posting Rod.
For others, I seen the lathe and steel stock stash and purchased a few bits and pieces - its all good.
30th Nov 2018, 02:40 PM #4Golden Member
- May 2003
- 526
There hasn't been any interest so I am posting pictures of tooling to see if it sparks an interest - there is a lot of tooling to make this package good value.. There will be quite a few posts as I am not sure of limitations on the forum.
This lot is a 5C collets and drawbar for the lathe
There is a set of metric and imperial collets so probably as much as you would need.Cheers,
Rod
30th Nov 2018, 02:52 PM #5Golden Member
- May 2003
- 526
This is the lathe, a holder screwed in the headstock to support long shafts and a tool height setter.
The lathe is an AL 336D so it has coolant and a DRO which sits on top (not in photo) and a foot brake.Cheers,
Rod
30th Nov 2018, 03:12 PM #6Golden Member
- May 2003
- 526
This lot is turning tools.
There are 20 boats and turning and borings bars as well as knurling and parting tools. There is the Eccentric turning tools included.Cheers,
Rod
30th Nov 2018, 03:19 PM #7Golden Member
- May 2003
- 526
And the usual lathe accessories. I have probably missed stuff like carbide inserts so if it is here it goes with the lathe.
Rod
30th Nov 2018, 05:34 PM #8Diamond Member
- Aug 2006
- 1,106
That is a bargain, someone will be getting a good deal.
Good luck with the sale.
4th Jan 2019, 10:29 PM #9Golden Member
- May 2003
- 526
Bump.
I have had no enquiries about the lathe. I keep getting requests for the tooling but have resisted except for the c5 collets and the collet closer. The price will obviously reduce because of this sale. Sadly I will give it another week and then Gumtree will have to be used.Cheers,
Rod
4th Jan 2019, 10:59 PM #10Diamond Member
- Aug 2006
- 1,106
Can't believe this hasn't sold yet, have you considered using eBay? I'm sure you would ge tmore than your asking price considering it comes with all those tool holders, dro and the material you will be including.
4th Jan 2019, 11:03 PM #11Most Valued Member
- Jul 2016
- 35
- 1,522
Seems nuts that this hasn't gone, especially considering I see pricy machinery sell all the time over there. Best of luck
5th Jan 2019, 01:47 PM #12Golden Member
- May 2003
- 526
No enquiries and nobody come to see it either.
Could be the time of the year also.Cheers,
Rod
21st Jan 2019, 07:29 PM #13Golden Member
- May 2003
- 526
Sold on Gumtree same day advertised.
Thanks to those that looked here.Cheers,
Rod
Electrician to repair 240 volt HM52 mill Western Sydney
By pipeclay in forum ELECTRICALSReplies: 2Last Post: 17th Apr 2017, 07:29 PM -
anodizing in melbourne western suburb
By thorens in forum METALWORK GENERALReplies: 0Last Post: 18th Oct 2016, 08:56 PM -
Western Suburbs Lathe Shops
By Plushy in forum METALWORK GENERALReplies: 0Last Post: 28th Aug 2015, 09:22 PM -
machine removalist service around Western surburb Vic
By thorens in forum METALWORK GENERALReplies: 4Last Post: 21st Jul 2014, 10:24 PM -
Lathe newbie seeks metal, western brisbane
By unixbigot in forum METALWORK GENERALReplies: 15Last Post: 17th Aug 2011, 05:54 AM
