Seig KX3 CNC Mill
$5000
Located - Aspley, Brisbane.
PM Damian
Single phase (240V) CNC Milling Machine.
Factory CNC - NOT A CONVERSION!!!!
Very little work, comes with a new fanless industrial PC in a custom enclosure with a IP67 Industrial Touchscreen. LAN connection, USB slots, Wireless keyboard.
Factory Sieg software included - running G-code
Full Collet set included - OZ 25 - 3 to 25mm
Remote pendent included
A work envelope of 295 mm (X-axis) x 150 mm (Y-axis) x 270 mm (Z-axis)
Face Mill Capacity - 80mm
Eng Mill Capacity - 25mm
Drilling Capacity - 25mm
Spindle Motor Rating - 1 KW
Spindle Taper - OZ 25
Voltage - 220 to 240 V
Frequency - 50Hz
Feeding Speed Max - 500mm/min
Rapid Moving - 2000mm/min
Spindle Travel - 270mm
Spindle Speeds - 100 to 3500 rpm
Repetition Oriented Precision - 1.01mm
Oriented Precision - 0.01mm
https://damianobrien.smugmug.com/Seig-KX3/i-WJ4HTmf/A
https://damianobrien.smugmug.com/Seig-KX3/i-tvVxgRw/A
https://damianobrien.smugmug.com/Seig-KX3/i-Pc22C4N/A
