Results 1 to 4 of 4
25th Jan 2017, 12:10 PM #1New Member
- Jan 2017
- 2
Bosch die grinder Perth will post $150 rrp $509
Bosch 240v GGS 28 LCE Professional
Lightly used, good condition. message for pics
Long cord.
Tool only.
$150 plus post if required- $15ish
Bosch GGS 28 LCE - 650W Professional Straight Grinder
Features:
Little servicing required due to significantly improved carbon brush lifetime
Constant Electronic for constant speed, also under heavy load
New clamping system for a secure fit of the grinding stones to ensure precise work
Cut-out corbon brushes for a high level of motor protection
Double sealed ball bearing for less vibration sensitivity when accessories are unbalanced
Direct cooling for high overload capability and long lifetime
Suitable for stationary use due to collar with 43 mm mount
Specifications:
No-load speed: 10000 - 28000 rpm
Toolholder: up to 8 mm
Rated power input: 650 W
Spindle collar diameter: 43 mm
Weight without cable: 1.4 kg
26th Jan 2017, 07:39 AM #2Senior Member
- Jan 2012
- Hinchinbrook
- 112
Can it be fitted with an accessory flexi-shaft?
Cheers Phil
27th Jan 2017, 01:23 AM #3New Member
- Jan 2017
- 2
I understand there are aftermarket kits which will do that- there are a number on eBay.
There is no Bosch accessory with a flex shaft though that I have come across.
You'd prob be better off with the GGS 28 CE for that application though- it's a cheaper tool and there is no point paying for the longer nose if you aren't going to use it. I could sell you a s/h one of those also....
22nd Feb 2017, 10:07 AM #4Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 272
I'm interested. PM sent.
G`Day from Perth
By .Jynx. in forum G'day mate - THE WELCOME WAGON -Introduce yourselfReplies: 4Last Post: 30th Dec 2016, 05:34 PM -
Bosch (Scintilla 16 Gauge Sheet metal Nibbler - Helensburgh NSW
By Chris Parks in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 18th Dec 2016, 09:42 PM -
Bosch 9" Grinder
By GSRocket in forum METALWORK GENERALReplies: 6Last Post: 24th Aug 2015, 08:14 PM -
J&E Ledger Perth
By rodm in forum METALWORK GENERALReplies: 8Last Post: 27th Jul 2012, 02:32 AM
