Results 1 to 8 of 8
    Mar 2005
    Blue Mts NSW
    68
    0
    Default LATHE HAFCO AL54a
    New Hafco AL54a, bought 2 years ago but has not been used, still in its protective grease. Was sold by Hare and Forbes with no guarantee on the motor.
    Swing 250mm.
    Between centres 750mm.
    Spindle taper 4MT.
    Spindle bore 26mm.
    Tailstock taper 2MT.
    Spindle speeds 125 – 2000rpm.
    Imperial threads 8 – 70 tpi.
    Metric threads 0.1 – 2.5 mm.
    Comes with 3 and 4 jaw chucks, faceplate, fixed and travelling steadies, change gears, dead centre, splash guard and drip tray.
    $875.00.
    Pick up only from Blue Mountains NSW.
    Jan 2004
    St George area, Sydney
    65
    22
    How big is it and what do you think it weighs?
    Do you have a manual?
    I couldnt find it on the current hafco website
    Mar 2005
    Blue Mts NSW
    68
    0
    I will post weight and dimensions when I get home tonight. It does come with a manual. I don't think it was ever in a Hare and Forbes catalogue as it was superceeded by the AL54b which is identical other than being able to swing 280mm
    Mar 2005
    Blue Mts NSW
    68
    0
    Weight is 130Kg, dimensions 1500mm long, 450mm deep, 460mm high.
    May 2006
    Canley Heights, NSW
    67
    529
    Quote Originally Posted by Lister View Post
    Have you ran it to see if the motor works.?
    Is it 240Volt
    Also, where abouts are you located.
    Thanks Shane.
    Mar 2005
    Blue Mts NSW
    68
    0
    Shane
    Yes I have run the motor and it does work, but I bought the lathe from H and F with no guarantee on the motor, the salesman told me about 50% of them have problems, so I cannot be sure it will continue to work indefinately.
    The motor is 240 V.
    I'm in Faulconbridge in the Blue Mts.
    Peter
    May 2006
    Canley Heights, NSW
    67
    529
    PM Sent.
    Mar 2005
    Blue Mts NSW
    68
    0
    The lathe has been sold
  1. Hafco bench lathe
    By colbra in forum METALWORK GENERAL
    Last Post: 25th Jul 2011, 09:05 PM
  2. Hafco lathe videos
    By steran50 in forum METALWORK GENERAL
    Last Post: 8th Mar 2010, 12:06 AM
  3. Old Hafco Lathe
    By snowyskiesau in forum METALWORK GENERAL
    Last Post: 1st Feb 2008, 11:05 AM
