Results 1 to 6 of 6
Thread: Identification problem
1st Jan 2009, 10:49 PM #1Novice
- Feb 2008
- Qld
- 10
I know it's not a Hercus but you guys are fairly knowledgable. I need help identifying this old lathe. The chuck has a USA inscription on it. I would say some things have been modified. The base and motor set up have. It originally had flat belt drive. It runs well, I was going to use it for small piece work but I think I might sell it. Any ideas as to what it would be worth?? Anyone interested before I put it on fleebay? Hope the pictures are clear enough?
2nd Jan 2009, 08:23 AM #2Member
- Sep 2008
- Prince George BC Canada
- 89
Chuck key!!!
No idea what it is, looks kinda sweet tho for a vintage machine.
Could you do us a favor and run to your machine and remove the chuck key....... big no-no with a lathe and it creeps me out whenever I see it. I work at a vocational school with 12 lathes and 10 mill etc and I can't count how many times the students have done that and started it up! Scary stuff!
hope I didn't come across too hard
regards
alRemember if the ID exceeds the OD the hole will be on the outside!
2nd Jan 2009, 08:42 AM #3Novice
- Feb 2008
- Qld
- 10
Idetification - Chuck keys
Sorry mate, I don't normally do that. It was just to show everything that goes with the machine. I'm an ex Manual Arts Teacher, hope no students are watching and hope you guys will forgive me.
It is a sweet little machine.
2nd Jan 2009, 09:20 AM #4Member
- Sep 2008
- 89
No problemo
Yeah ya gotta hope the students catch the master.... lol!
3rd Jan 2009, 05:35 PM #5Senior Member
- Jul 2007
- 112
Interesting headstock setup.
Looks like an early wood lathe with additional feed screw setup mounted in rest.
The motor gearing is certainly a high speed.
Maybe used for accurate wood machining like pattern making?
Is the headstock mounted in a ball bearing setup?
Regards, Peter
3rd Jan 2009, 10:19 PM #6
Could be a metal spinning lathe .If not it would make a good one.
Kev"Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
Groucho Marx
