Results 16 to 23 of 23
Thread: Hercus Lathe Oil
28th Jul 2008, 10:59 PM #16chris
- May 2005
- melbourne
- 53
- 40
I have only used Vacuoline type way oil in my lathe. bridgeport. grinder. ect it workes plus i get it for free from a frend but only in small amounts
4th Aug 2008, 12:53 AM #17Golden Member
- Apr 2008
- NSW
- 537
For your bedways Shell Tonna s680 Slideway oil. For the sleeve bearings the most important thing is the oil viscosity.It should be thin enough to go through the oil cups but not so thin that it runs straight out of the bearings.Lathes with enclosed quick change gear box are a different situation they use hydraulic type oils. This allows any contaminates to quickly fall to the bottom of the gear case and does not foam up.Vacuoline is an oil that satisfies hydraulic systems and has good corrosion protection for the bed ways also. It should be a good alround choice also.Velocite 10 is a high speed spindle oil mainly for close tolerance bearings it is very similar to Vacuoline being used in hydraulic systems and having low foaming . However it thinner in viscosity.If the sleeve bearings are tight then this oil is suitable but if they have some wear use a thicker oil.
16th Aug 2008, 08:19 PM #18New Member
- Dec 2007
- Toronto NSW
- 4
16th Aug 2008, 08:24 PM #19Most Valued Member
- Oct 2007
- 3,112
Using compressor oil, specs seemed to match spindle oil pretty much, maybe not quite as good, who knows. Get it from the same source.
16th Aug 2008, 08:28 PM #20New Member
- Dec 2007
- Toronto NSW
- 4
You mean Bunnings?
16th Aug 2008, 10:22 PM #21Most Valued Member
- Oct 2007
- 3,112
Yes Bunnings sells compressor oil, in tool section. Not expensive
23rd Sep 2008, 12:23 AM #22Senior Member
- Mar 2007
- Canberra
- 67
- 179
When you say Compressor Oil are you referring to Air Line Oiler Oil or oil you put into the compressor. I was just looking at details for Mobil Velocite No:10 and it's saying it's suitable for inline air oilers.
I'm just going through this whole oil scenario thing again for the umpteenth time and I'm still totally confused. Everything I know I 'should' be using I can only get in 20 litre quantities.
Went into Supercheap on the weekend to get some Tellus hydraulic oil based on what I've been reading here in the forums. They only had 32 and I wasn't sure about that so left it. Have since done some reading on the Shell site and they are saying not to use straight Tellus on chrome plated components, use Tellus S instead. I'm not sure if I have any chrome plathed stuff on the lathe or the mill so better to err on the side of safety and go for Tellus S. Don't know yet if this is available in 5 litre quantities but my bet would be NO.
At the moment I'm using Singer Sewing Machine Oil on the spindle, Chainsaw Oil for ways on mill and lathe and a general purpose oil for everything else.
Total confusion. You wouldn't think getting oil for the lathe and mill could be so frustrating. Oils ain't oils.
23rd Sep 2008, 09:19 AM #23Most Valued Member
- Oct 2007
- 3,112
Well the inline oilers will technically be oiling the tools not the compressor, and it's very light stuff. No the compressor oil is designed for the compressor itself, find it in the tool section of Bunnings.
Yes oils aint oils but at the end of the day it's there simply to lubricate a relatively low speed spindle under light load at room temperature. Compared to the demands some modern manufacturing machines place on their lubrication systems this is not a big ask. I would guess if the oil used was too thin in a total loss system it would migrate through faster than desired but at the end of the day chances are most here probably pamper their toy and keep it well oiled so are unlikely to run the bearings dry.
Pete
Hercus 260 as a first lathe?
By dpw700 in forum METALWORK GENERALReplies: 15Last Post: 10th Nov 2012, 09:28 PM -
Hercus 260 Metal Lathe
By Mark Robertson in forum METALWORK GENERALReplies: 9Last Post: 19th Jun 2008, 12:40 AM -
Hercus lathe logo
By neksmerj in forum METALWORK GENERALReplies: 19Last Post: 5th May 2008, 03:11 PM -
Hercus Lathe
By Penpal in forum METALWORK GENERALReplies: 16Last Post: 14th Feb 2007, 02:18 AM -
9 inch Hercus Lathe
By brianc in forum METALWORK GENERALReplies: 4Last Post: 18th Oct 2006, 04:34 PM
