Results 1 to 6 of 6
    Oct 2019
    Nth Queensland
    55
    Default Weights of Moedl 0 and Hercus Shaper
    Cany anyone help me with the weights of the Model 0 Mill 3slot, and Hercus shaper? Need to relocate mine. I have searhed previous threads, found some details on the 260 ATM, but then I m a bit challenged .
    Terry
    Oct 2019
    Adelaide, SA
    1,198
    The Hercus Model 0 as per the spec sheet that was shared on this forum a while back:
    This is for the 2 slot version and the 3 slot should be slightly heavier. Probably 10% or so heavier since some of the castings are slightly different.
    No idea on the weight of the Hercus shaper.
    PS: Can pay for the freight if you need me to indefinitely store the 0 mill for you
    May 2011
    Murray Bridge S Aust.
    5,942
    You're a cheeky blighter, Kaffie.
    Oct 2019
    Nth Queensland
    55
    Thank you for the reposnse.
    Thanks for the offer Kaffie. Not wanting to part with it yet. Rest assured though that if I ever do I will give the forum first offer. Great place good people.
    Terry
    Oct 2019
    Adelaide, SA
    1,198
    I was just practicing some of Kryn's moves
    Aug 2014
    Brisbane
    38
    See attached info for the Hercus 270 shaper.
    Its says 300kg, its also shows where to sling
    Attached Files Attached Files
  1. Easy movement of heavy weights.
    By azzrock in forum TIPS, TRICKS & HOW TO'S
    Last Post: 21st May 2021, 09:30 PM
  2. Window weights
    By Simplicity in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 28th Feb 2021, 10:56 AM
  3. Moving machines, weights
    By j3dprints in forum METALWORK GENERAL
    Last Post: 14th Mar 2019, 07:37 PM
  4. Manufacturing spoke weights. How were these made?
    By gjws in forum METALWORK GENERAL
    Last Post: 15th Jan 2018, 04:43 AM
  5. rusty gym weights - any advice?
    By Mindabout in forum METALWORK GENERAL
    Last Post: 30th Apr 2010, 10:54 PM
