Results 16 to 19 of 19
Thread: Painting Query?
19th Aug 2022, 12:29 PM #16
Looking for something else I found an old White Knight paint chart, sent the photo to my mate, now have a litre of Marine Blue.
19th Aug 2022, 01:14 PM #17
More questions.
The WhiteKnight paint tin say to clean up with Rust guard solvent or turps, is this what I thin it with?
To paint a galvanised surface it says to etch prime first.
I have a tin of HiChem Super Etch Primer, the tin says to clean up with Superglow multipurpose thinners, can I use turps?
I got a couple of litre of Dulux Metalshield Epoxy Enamel, they say to use Metalshield Brush Thinners or Metalshield spray thinners, once again is turps compatible.
21st Aug 2022, 08:32 AM #18
Hi Mark,
I would test for compatibility by using a dab of paint on a lolly stick and seeing if the turps dissolves it without clotting !Best Regards:
22nd Aug 2022, 10:08 AM #19Banned
- Sep 2021
- 73
- 117
If it's enamel you can thin with enamel thinners, turps or petrol, but check with a small amount first and don't mix the paint thinned with different thinners together. Paint don't stick to galvanising to well, there are a number of treatments for galvanising from hardware stores, or, you can just wipe down with white vinegar first. Etch primers are for bare metal, not necessarily for galvanising. Most paints don't require etch primers these days.
You should always clean the surface to be painted with wax and grease remover first and don't touch with your hands after cleaning.
Enamel is not the best choice of paint, difficult to touch up unless Hammertone. I'd use 2 k, super hard and easy to touch up. Expensive though.
painting and priming
By Ryan in Melbour in forum METALWORK GENERALReplies: 10Last Post: 12th Jul 2016, 02:04 PM -
Another Painting Query
By Anorak Bob in forum METALWORK GENERALReplies: 9Last Post: 21st May 2015, 09:51 PM -
Painting machines
By .RC. in forum METALWORK GENERALReplies: 187Last Post: 17th Sep 2013, 12:33 AM -
Painting
By Anorak Bob in forum METALWORK GENERALReplies: 20Last Post: 6th Jun 2012, 10:55 AM -
Painting Aluminium
By Wood Butcher in forum METALWORK GENERALReplies: 2Last Post: 1st Mar 2006, 07:56 PM
