Results 1 to 5 of 5
6th Mar 2022, 02:58 AM #1New Member
- Jan 2022
- Alberta
- 2
Hercus 260 ATM Pulley shaft removal
Hi all, I've acquired a 260 lathe and have been disassembling it to clean and check it over. It has a few issues which I'll be asking you fine folks about.The first is how to remove the shaft that holds the speed reduction pulleys. It seems to have sealed bearings in the housings on either end but I don't know whether the shaft should press out from the bearings or do I have to somehow remove the housings from the lathe first?
6th Mar 2022, 10:26 AM #2Senior Member
- Aug 2015
- 239
Hi, The easiest way to get it apart is remove the assembly, there is a grub screw that holds the pivot shaft in place on the right hand side (close to the tension lever), push that out and then undo the bolt holding the the 2 halves together, just be aware there is another key on the shaft as well on for the cone pulley that may cause an issue if you are trying to press it out and were not aware of it.
6th Mar 2022, 02:35 PM #3Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
Page from Hercus 260 Lathe Maintenance Manual
7th Mar 2022, 05:25 AM #4New Member
- Jan 2022
- Alberta
- 2
Thanks, I did remove the whole assembly and then it did become obvious. I also had the opportunity to do it all again as I installed the wrong belt...
7th Mar 2022, 04:13 PM #5Senior Member
- Aug 2015
- 239
You only need to push the shift half way through and undo the bolt and swing one side up to change the belt on the counter shift if it is the later split type
Sheraton 9'' model A counter shaft step pulley
By tharindu in forum WANTED TO BUYReplies: 0Last Post: 4th Jun 2020, 08:46 PM -
Hercus #3A or #1 T&C smaller wheel guard and Hercus #3A wheel shaft pulley.
By lamestllama in forum METALWORK - Machinery, Equipment, MARKETReplies: 8Last Post: 30th Aug 2019, 12:01 PM -
Lathe chuck removal shaft collar wedges
By ml018 in forum METALWORK GENERALReplies: 3Last Post: 27th Aug 2018, 06:35 PM -
drill hole through new shaft to align with pulley taper holes
By MarkBrown in forum METALWORK GENERALReplies: 13Last Post: 9th Sep 2016, 08:20 PM -
pulley removal
By shaper07 in forum METALWORK GENERALReplies: 2Last Post: 17th Apr 2015, 10:45 PM
