Results 1 to 8 of 8
    Jul 2021
    Toowoomba
    6
    Default Fitting a single phase motor
    Hi guys, this is my first post on the forum. I am putting one of the techtop single phase motors onto my 260, but have discovered that the drive frame casting prevents it from fitting into place. I've seen some mentions on other threads about modifying the casting to take a larger motor but am nervous to go for it without getting some advice first. Can anyone please tell me whether cutting into the casting to create space for the motor is a good or bad idea? The photo is to show what I would be cutting away, in case I haven't done a very good job of explaining. Any help will be appreciated. Thanks
    Aug 2015
    Adelaide
    240
    Hi Craig
    You can cut away at the frame safely without any issues, you can cut it with a jigsaw, for some reason the there was 2 different castings with the different size cutouts and that seemed to be on C model lathes.
    Regards Steve
    Jul 2021
    Toowoomba
    6
    Hi Steve, thanks for the reply. Just wanted to make sure I didn't do something stupid and irreversible. I'll probably end up doing it by hand with a hacksaw as I don't have good blades for the jigsaw.
    Jan 2009
    Holbrook, NSW
    73
    490
    Default motor fitting
    Hi Craig,
    Cutting out the casting to fit the standard motors, available today, is something that just has to be done. The Asea motors, that Hercus fitted in some of their later machines, had a much lower profile. Most of the cheaper standardised types sold today are considerably larger. Even with the Asea motors, they still come with larger bodies as the horse power increased. Although some castings have a big enough opening, generally If you add a 3/4 hp to a machine that previously a 1/2 hp or an Asea motor, some modification will be necessary. This won't affect the function of the machine at all.
    Mal
    Oct 2004
    Southern Highlands NSW
    1,898
    Single phase motors are often more "lumpy" than 3 phase, because as well as a terminal box they have a capacitor or two that are attached to the motor body.
    The size and location varies between makers. I had to check various motors before finding a Teco that would fit my 260.
    The cap housing was not obstructed, but I did have to lower the terminal box a bit.
    I had the electrician retain the contactor switch and no-volt release safety feature.
    He installed a 240V part into the contactor so that would work.
    Oct 2004
    1,898
    This motor has been fitted to a Hercus 260 with no modification.
    The bulky terminal block and capacitor are on the opposite side from the foot mounts, and didn't obstruct anything.
    https://www.ebay.com.au/p/4034409367
    Dec 2011
    Sydney
    505
    Motors like that have bolt-on feet that can be fitted on any of the three 'sides' of the motor other than where the capacitor housing is located. It's very helpful in some situations.
    Bill
    Aug 2009
    Adelaide
    27
    Default Motor casting modification
    Here is a Hercus 260 modification to accept a single phase motor I did recently.
    Tools are good, more tools are better!
  1. Replies: 6
    Last Post: 12th Nov 2021, 07:01 PM
  2. 3 Phase Generator Motor Powered by Single Phase Motor?
    By gazza2009au in forum ELECTRICALS
    Last Post: 4th Apr 2020, 04:38 PM
  3. Single phase Vs 3 phase motor ratings.
    By KBs PensNmore in forum ELECTRICALS
    Last Post: 17th Sep 2017, 05:37 AM
  4. Replies: 26
    Last Post: 1st May 2015, 04:42 PM
  5. Replies: 7
    Last Post: 10th Mar 2014, 07:26 PM
