Results 1 to 7 of 7
    Aug 2012
    Greenmount, W.A.
    70
    275
    Default Hercus O Mill Keyway on arbor.
    Finally got my O Mill running. Found running clockwise (looking from front of Mill) was best.
    The arbor is 1" in diameter, and the cutters I have all have a keyway, but the arbor does not. Friction alone stops the cutter from slipping. Seems a bit odd to me! I can't tighten the arbor nut up sufficiently to stop slippage. I don't have a spanner on the arbor proper, only on the nut (at the end). Have I missed something?
    6,475
    Hi Alan,
    Often there are a pair of spanner flats on the drive end of the arbour !
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Can you hold the nut on the arbor draw bar.
    I would suggest if possible to get a keyway cut into your arbor, friction may work for you but I think you will be limited to very shallow depths of cut.
    Aug 2012
    Greenmount, W.A.
    70
    275
    Thanks for the replies. Agreed, the ultimate solution is a keyway. Especially as my physical strength is waining!
    Mar 2012
    South Australia
    33
    DO NOT machine a key-way on the arbor.
    It is better for the cutters to be held by friction. If the cutter jams it is more likely to spin on the arbor.
    If it is held by a key the cutter will shatter
    Find the flats at both ends and use spanners /shifters to tighten.
    Oct 2001
    ACT
    667
    the hercus mills are small and generally you can only take light-ish cuts, and generally no need for the keyway as already said
    their is no spindle lock so I tend to engage the back gear - not generally great as there's a risk of back gear damage if you over do it - but you dont put all your weight on the spanner and generally its easy enough to get the arbour done up enough.
    Failing that, You may also be able to make up some kind of C type spanner to engage where one of the square spindle keys are while you have the spanner on the nut at the other end of the arbour.
    Nov 2008
    Perth WA
    6,459
    AJ,
    I've have used the keyway-less horizontal arbor on my little No.O a fair bit. I tighten the arbor nut by simply locking the back gear. I haven't snapped any gear teeth off.
    If you were concerned about tightness you could hold the arbor in a bench vice by clamping across the arbor's flange drive slots then tighten away to your heart's content. Or you could drill a radial hole in the arbor's flange and use a pin spanner to prevent rotation thereby posing no risk to any gear teeth.
    BT
  1. Indexable carbide end mill for keyway cutting.
    By Karl Robbers in forum METALWORK GENERAL
    Last Post: 21st Jun 2020, 11:26 PM
  2. HELP - Novar Horizontal Mill Arbor
    By seafurymike in forum METALWORK GENERAL
    Last Post: 22nd Jan 2019, 11:59 PM
  3. Removing the Hercus O Mill Standard Arbor
    By NoobHercusOwner in forum THE HERCUS AREA
    Last Post: 12th Jun 2018, 07:31 PM
  4. 1 1/4" mill arbor
    Last Post: 2nd Oct 2014, 09:02 AM
  5. Face Mill Arbor Question. CTC?
    By Greg Q in forum METALWORK GENERAL
    Last Post: 1st Feb 2011, 05:52 PM
