Page 1 of 2 12 LastLast
Results 1 to 15 of 21
    Dec 2021
    gold coast
    4
    Default just wondering if anyone knows where to get parts forhercus 270 shaper
    sorry i know this is off topic but there are no other places to post on this subject, but i would be very grateful for anyone able to point me in the rite direction to some one who has parts or knows someone who does the part for a hercus 270mm shaper, i am after is the ratchet gear and pawl also if some one has the dimensions of the items ie diameter of ratchet gear and tooth count, my contact mobile (deleted by moderator) or on here fine thanks donny.
    Jan 2004
    Mackay North Qld
    6,446
    Hi Donny ,
    Welcome to our Metalwork Forums.
    I deleted your mobile number as this forum can be internationally accessed. That means that scammers worldwide only have to read our forum and bingo, good old Donny is driven nuts by unwanted phone scammer attention. We highly recommend you don't put personal information on line, here or elsewhere.
    Without doubt people from the Hercus forum will reply to you via the Hercus forum in due course, if the parts are available. There are many Hercus machine owners and enthusiasts here and will welcome you and offer their input and experience.
    There is a great mob here who go out of their way to assist new guys.
    Most metalwork interests are catered for. To have a looksee do the following;
    To navigate our Forums click on the FORUM box at the LH top of the page.
    A drop down menu will appear and click on FORUM HOME which will give you a scroll down page with all of our various sub forums and other helpful things.
    Our forum rules, the TOU's are on top and the rest is the sub Forums and help pages that make up our forum package.Please make sure to read through them.
    Anything else you need to know,please PM me and I will help If I possibly can.
    Jul 2008
    near Warragul, Victoria
    3,718
    Hi
    The forum member from Canberra 'Ueee' made some of the ratchet gears some years ago.. he sent me (and others) a new ratchet gear for the Douglas shaper .
    Unfortunately he hasn't posted on this forum for a long time.
    Jan 2004
    Mackay North Qld
    6,446
    Ueee last posted in 2017 .
    His business, 84 Engineering was manufacturing his range of linishers and and spare parts for a retail mob Artisan crafts or something like that.
    Last time I sought belt grinder spare parts from 84 Engineering I was referred to the Artisan supplies mob who still had no stock.
    I do not know for sure but would guess Ueee was/ is flat out catching up.
    You might chase up his website and email him.
    Given the time of year many of our members could be away. Be patient for a few weeks and some may reply.Its the silly season and Wuhan Flu has exacerbated the problems normally suffered around this time
    Otherwise I am unable to suggest anything.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,541
    If someone can supply drawings...
    May 2013
    Rockhampton, QLD
    68
    454
    Welcome to the forum Donny.
    Ross
    Jan 2004
    Mackay North Qld
    6,446
    The link below may contain interesting information to the Hercus 270 shaper which had a history before Hercus acquired it.
    Douglas & Hercus ShaperAustralia
    Oct 2011
    59
    6,541
    Donny, I've taken a picture from the page Grahame's post linked to and circled the bits I think you are chasing. Can you confirm that these are them (and only them - you don't need the casting the pawl sits in for example...)
    Oct 2004
    Southern Highlands NSW
    1,894
    Measured my pre-Hercus, Douglas shaper ratchet wheel.
    It looks identical to my 270's, but I can't get close enough to measure it.
    Jul 2008
    Sydney Australia
    142
    Quote Originally Posted by ratgunfighter View Post
    I'm guessing you have a (Hercus) shaper that is missing these parts - question is do you have or have access to a lathe ?
    With these two machines you could maybe make the bits AND gain valuable experience yourself along the way, perhaps ?
    Oct 2004
    1,894
    Quote Originally Posted by greg_n View Post
    Yes, it could be made on a shaper, if you also have an indexing spindle or similar for the 24 grooves.
    Nov 2017
    Geelong, Australia
    57
    2,651
    For 24T the “similar” could be as simple as a hex nut and a DTI.
    Oct 2004
    1,894
    How is that done, please?
    Nov 2017
    Geelong, Australia
    57
    2,651
    Quote Originally Posted by nadroj View Post
    Take a hex nut, or bolt (anything with a hex on it) and attach to the end of the part you need to index. It doesn't need to be perfectly aligned axially.
    Support/clamp the part in vee blocks or vice etc.
    Set a flat of the hex horizontal - make your first cut
    Now if you rotated until the next flat was horizontal, then did a rinse and repeat - you'd end up with only 6 divisions, ie one per flat.
    But if you only rotate the part until a flat is vertical - you'll end up half way between those horizontal flat positions, and therefore get 12 divisions.
    So slowly rotate and cut each position - in the flat-horizontal, flat-vertical, flat-horizontal sequence. The DTI is used to sweep the vertical and horizontal faces, (or you can use any other method you want such as a level and a square etc).
    You've now got 12 nice divisions/teeth.
    Find the half way point between 2 of the divisions - clamp the part in that position and align the hex so one face is horizontal.
    Repeat what you did for the first 12 divisions - and you'll have 24 (or at least that's how it comes out in my head).
    Plenty of low tech methods involving common tools or simple geometry to get these nice multiples of 2,3 and 4 divisions.
  15. #15
    Dec 2021
    gold coast
    4
    Default 270 hercus shaper parts
    thanks guys for all your help. im new to posting and using forums if im doing something wrong or going the wrong way about it its because im lost in space. i have access to a lathe i will make one and i will post pictures regards donny
  1. Shaper, 18" Macson (Alba) shaper Brisbane
    By pedro54 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 9th Jul 2019, 12:02 PM
  2. First time welding and wondering what I'm in for.
    By bradyofdoom in forum METALWORK GENERAL
    Last Post: 24th Jan 2019, 08:16 PM
  3. Thinking aloud....wondering...
    By kekemo in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 22nd May 2007, 09:49 PM
