Results 1 to 4 of 4
24th Dec 2021, 07:39 AM #1Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,185
How to scribe an index line on your cross slide
The old Hercus cross slides (or, as their parts manuals call it, the compound slide base plate?)
have a pair of zero marks – one on the front, and one on the back – to align with the nicely engraved protractor on the rotating compound casting.
If you use the compound at more than +30°, the front mark will be covered, and I never remember to use the back mark. Out of sight, out of mind?
What I needed was one facing the chuck.
1) Use a fine pen to mark the location beside 90° on the protractor:
2) Remove compound slide assembly, and attach a tool, somewhere, to engrave over the mark.
A scriber (or Dremel) well clamped to the bed would do,
but I found an easier way - a boring bar in the chuck:
3) Push the scribing tool into the casting with your left hand, and crank the carriage/saddle toward it a few times with your right:
swinging the tool up between passes to be nice to the carbide (by turning the chuck a little).
4) Now there is a decent groove, carefully hand scrape a few times to finish it off:
et voila:
24th Dec 2021, 08:28 AM #2Golden Member
- Sep 2009
- 666
Very clever. Was yours an old school machine? That compound casting has been well introduced to the chuck
24th Dec 2021, 01:52 PM #3Diamond Member
- Aug 2019
- 56
- 1,185
24th Dec 2021, 08:41 PM #4Most Valued Member
Sheraton cross slide and compound slide spindle threads
By ajbvicau in forum SHERATON AREAReplies: 5Last Post: 20th Jul 2021, 10:43 PM -
Wringing cross slide?
By Malibu in forum THE HERCUS AREAReplies: 11Last Post: 12th Nov 2019, 01:44 PM -
Cross-slide play
By jack620 in forum METALWORK GENERALReplies: 23Last Post: 19th May 2012, 07:50 AM -
Cross Slide Nut
By raypat in forum METALWORK GENERALReplies: 19Last Post: 9th Dec 2011, 01:41 AM -
sheraton A cross slide nut
By danielhobby in forum THE HERCUS AREAReplies: 5Last Post: 21st Apr 2011, 07:50 PM
