Results 1 to 10 of 10
17th Dec 2021, 02:35 PM #1Senior Member
- Aug 2021
- 46
- 117
Hercus 9 vs Sheraton 9 vs Southbend 9 centre heights?
I read somewhere that the Sheraton 9 was nominally 1/8" higher than the Hercus 9? What about the Southbend? Can anyone enlighten me? I've been searching for the info but cannot find it again. Thanks.
19th Dec 2021, 03:04 PM #2Senior Member
- Aug 2021
- 46
- 117
Still been looking and can't find anything. But I am sure I read somewhere that the centre height on the Sheraton was 4 5/8 whereas the Hercus was 4 1/2. But following on from a conversation I had with someone recently I have a feeling I could be chasing after the proverbial furphy water cart.
I do have access to both a Sheraton and Hercus, though neither have a tailstock and I'll need to figure out how to accurately measure the center height , and I'm not exactly certain that the headstock on the Sheraton is original, but I suppose I shall start looking for clues.
Why do I find I need to precisely know such things?
19th Dec 2021, 05:42 PM #3Most Valued Member
19th Dec 2021, 07:29 PM #4Senior Member
- Aug 2021
- 46
- 117
Problem being that neither machine is a going concern with key bits missing from each. I am trying to make a working machine out of the bits that I have collected.
I could put something pointy in the chuck, or a centre in the spindle and measure down to the top of the flat way.
My second trade is as an electronics technician. An inquisitive mind is probably the answer to my own question and makes for a good tech, I was actually taught to be that way in my trade. The real reason was that I wondered about compatibility of parts between the two makes. But my mind gets caught up on such things and so I agree that you are right in a way!
19th Dec 2021, 09:02 PM #5Senior Member
- Aug 2015
- 240
If you have access to both machines then why don't you put something flat across the ways and measure from the top or bottom of the thread on the spindle down and compare the difference, at least you will solve it if there is a difference between the height.
20th Dec 2021, 08:02 AM #6Most Valued Member
You're going to need a tailstock. I can't see any way around that. Here's a Hercus one: https://australianmetalworkinghobbyi...product_id=131
21st Dec 2021, 09:07 AM #7australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
21st Dec 2021, 10:17 AM #8Senior Member
- Aug 2021
- 46
- 117
Thanks kindly for the info Mal. Maybe I can find the Sheraton drawing or a spec sheet on the internet somewhere (I have been googling, but it just came to front memory (if that is a thing) that some of the fb social media groups have file download areas I could check)
Thanks, I've been in touch with Mal about some other bits a few months ago, very nice site, nice guy to talk to, just its a long term project, I start a new job in January but it has been a dry stretch for the last few months so have been held up on the project due to these kind of constraints. But will get there.
21st Dec 2021, 01:36 PM #9australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
centre height
That height I gave you is from the flat way the forward edge of the tailstock sits on.
29th Dec 2021, 05:18 PM #10Senior Member
- Aug 2021
- 46
- 117
Today I had access to both machines, if anything, the Hercus may have been approx 1/32" higher than the Sheraton, (rough measurement with a tape measure) so likely they are nominally the same height, perhaps comes down to my tape measure inaccuracy or maybe there is a small difference but a lot less than the 1/8" that I had read about. So most likely the reference I had seen citing 1/8" difference in centre height was a furphy. Thanks guys for the thoughts and for the information from Mal.
9 inch hercus/southbend lathe.
By mathuisella in forum METALWORK - Machinery, Equipment, MARKETReplies: 7Last Post: 5th Aug 2021, 10:09 AM -
Al-320G handwheel heights
By SurfinNev in forum METALWORK GENERALReplies: 8Last Post: 23rd Feb 2017, 09:21 PM -
Hercus and Southbend
By neksmerj in forum METALWORK GENERALReplies: 2Last Post: 26th Sep 2015, 08:43 AM -
Crotch Centre for Hercus Lathe
By Abratool in forum METALWORK GENERALReplies: 3Last Post: 31st Aug 2012, 08:02 AM -
Hercus Lathe old Southbend 9"
By VicTrack 1 in forum METALWORK GENERALReplies: 0Last Post: 9th Apr 2008, 03:53 PM
