Results 16 to 30 of 31
Thread: An unusual Hercus!
28th Jan 2022, 08:07 AM #16Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
Yep. Here is a sample, gravity cast in an old cylinder bore:
The core die:
Eventually, these will be churned out by a centrifugal casting machine (which I started to document elsewhere).
28th Jan 2022, 08:11 AM #17Diamond Member
- Aug 2019
- 1,196
More painted parts
The coolant pump:
its cast iron tank:
and some other random bits:
28th Jan 2022, 09:36 AM #18Most Valued Member
Thanks for the updates Nigel.
What are the pistons for, besides an engine of course??
You must be expecting to go through a few to go to all this trouble!!!
29th Jan 2022, 02:56 PM #19Diamond Member
- Aug 2019
- 1,196
Austin Sevens. The vintage engine guy isn't happy with the recent quality of J.P. pistons. (and the imported English ones aren't any better)
Instead of having to re-machine the expensive ones they would sell him, starting from scratch, with highly eutectic alloy, is the current plan.
Here is a cutaway of another gravity cast piston:
29th Jan 2022, 03:01 PM #20Diamond Member
- Aug 2019
- 1,196
trial assembly
Struggling a bit, because we lost pre-stripdown photos. Need someone with access to the factory archivesLast edited by nigelpearson; 29th Jan 2022 at 06:27 PM. Reason: more photos
1st Feb 2022, 07:34 PM #21Diamond Member
- Aug 2019
- 1,196
Bed for the sliding parts now fitted:
This is the old "General Electric" motor that drives the spindle and its offset(ing) cam:
Note the slightly slanted rotor cores, kind of like a synchronous motor.
it hides behind the top left guard here:
1st Feb 2022, 08:32 PM #22
3rd Feb 2022, 09:22 PM #23Diamond Member
- Aug 2019
- 1,196
Mostly together
Only thing left is the grinding wheel motor and belt, and wiring.
Note the inside of the Compton 2HP motor:
Nice brazed bronze castings that form a fan to provide airflow through the "squirrel cage?"
11th Feb 2022, 08:57 AM #24Diamond Member
- Aug 2019
- 1,196
Mostly assembled. It grinds
Still need to work out a tensioner for the left (spindle rotating) motor,
so its guard isn't there yet, but assembled enough:
for a quick grind test on an old piston:
Still to do is some automation of the longitudinal feed. The vintage engine guy wants to attach a mill "power feed" unit, but the pinion on this bed/table is too direct – half a turn on the lever moves about 45mm – which would grind a spiral with your typical mill cranking rate.
Have to work out a reduction gearbox, and somewhere to mount it.
11th Feb 2022, 09:30 AM #25Golden Member
- May 2020
- Willowbank QLD
- 535
Why not get a three phase power feed and use a VFD?
11th Feb 2022, 10:44 AM #26Diamond Member
- Aug 2019
- 1,196
11th Feb 2022, 03:10 PM #27Most Valued Member
Isn't a mill power feed unit variable speed, or is it still too fast at it's slowest rate?
Would it be possible to use a stepper motor etc to drive it, that way you would have infinite control over it?
What sort of ratio would you need, I think I've a couple of right angle drives about 60:1, if that helps?
11th Feb 2022, 03:29 PM #28Senior Member
- Aug 2015
- 240
That has come up real nice .
11th Feb 2022, 05:06 PM #29Diamond Member
- Aug 2019
- 1,196
They are variable speed, but like most AC & DC motors, power drops off a lot at lower voltages (or PWM duty cycle). He thinks still way too fast (the Hercus pinion is too direct).
A large stepper would work (or a small one geared down),
but a power feed has end stops, and a convenient direction handle.
He is thinking hundreds to 1. I suspect that would be too slow. We will have to experiment. RS has a few that might hold up to the load for a while:
https://au.rs-online.com/web/p/gearboxes/0424065
https://au.rs-online.com/web/p/gearboxes/0424027
11th Feb 2022, 06:39 PM #30Diamond Member
- Aug 2019
- 1,196
this has machine the sort of feed rate he is after. A Repco connecting rod boring machine:
There is a lead screw up the middle. A very fine lead screw. Maybe 50 or 60 TPI. It might take 45 seconds to bore through a 1/2" big end bearing.
This machine also has an odd/ingenious attachment for cutting a figure-8 groove in the bearing:
IMG_2506.jpgLast edited by nigelpearson; 11th Feb 2022 at 06:54 PM. Reason: grammar
Unusual tap
By kenny_10 in forum METALWORK GENERALReplies: 9Last Post: 8th May 2018, 06:23 PM -
Unusual tool - what is it?
By Alf Scotting in forum METALWORK GENERALReplies: 4Last Post: 7th Oct 2017, 11:42 AM -
An unusual later model Hercus lathe
By kwijibo99 in forum THE HERCUS AREAReplies: 3Last Post: 23rd Jun 2016, 12:50 PM -
Unusual Hercus for Sale on Gumtree at Caboolture QLD
By A J in WA in forum THE HERCUS AREAReplies: 2Last Post: 14th Feb 2014, 04:24 PM -
Unusual drills
By bollie7 in forum METALWORK GENERALReplies: 11Last Post: 11th Aug 2012, 07:39 PM
