Results 1 to 4 of 4
    Aug 2020
    brisbane
    42
    2
    Default Motor conversion Hercus 9inch AR 1970s
    Hi, I have just acquired a Hercus 9" AR model, built around 1970s (#13250).
    I want to (if possible) convert the 3phase motor to use with VFD, so single phase (domestic) -> VFD -> 3phase motor
    I'm a complete inept at electrical stuff...
    A few questions regarding the motor (original), which is .5hp, 3phase, unknown voltage (as that part of engraving/plate is not legible):
    - Is the original motor 240v or 415v?
    - Given the picture of the junction box (or whatever you call it), does this require star -> delta conversion? or is it just impossible to be used with VFD?
    - Someone said that if the motor is a 3-phase 240v, all I need is a matching VFD (i.e. .5hp rated VFD) and there should be no loss in power, however if motor is 3-phase 415v, i need to double the VFD to 1hp, is this correct?
    - What is the best way forward to get the motor going? I believe the original motor still works as the guy that sold to me said so; or is it better to just get one of those new motor + VFD packages from ebay?
    David.
    7,188
    These Hercus motors are 415V "STAR" connected and need to be doctored internally to be converted to "DELTA" to be able to run on 240V 3Phase, as provided by a 240V single phase VFD.
    OR
    You can use an Ecogoo VFD which converted 240V single phase direct to 415V 3 phase and no motor mod is needed.
    Do a search for Ecogoo VFD in these forums and you will see them discussed in some detail.
    Aug 2020
    brisbane
    42
    2
    OR
    Thanks Bob, do you / anyone know if the .75kw (1hp) version of the Ecogoo VFD supports stepping power down to .5hp to run the original .5hp 3phase motor? Or does it not allow you to change like the Vevo?
    Also chasing the original motor specs if anyone have it
    7,188
    Quote Originally Posted by dzhu View Post
    I believe it is possible set a current limit on the Ecogoo VFD - the 750W Ecogoo VFD probably uses a current limit of ~4A , so for the 375W motor I would limit that to say 2.5 or 3A and you should be OK. Someone with an Ecogoo will hopefully pipe up and answer this question.
  1. DC motor conversion
    By errolf2 in forum THE HERCUS AREA
    Last Post: 14th Aug 2020, 09:05 PM
  2. Hercus 9inch travelling steady castings
    By Swarfmaker1 in forum THE HERCUS AREA
    Last Post: 30th Mar 2019, 10:05 AM
  3. Hercus Lathe motor Star to Delta conversion,
    By LexD in forum THE HERCUS AREA
    Last Post: 14th May 2018, 10:59 PM
  4. Replies: 11
    Last Post: 29th Apr 2017, 05:59 PM
  5. 7 X 12 motor conversion???
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 10th May 2015, 07:31 PM
