Results 1 to 14 of 14
Thread: Do I need more gears on 260ATM?
6th Nov 2021, 07:55 PM #1Novice
- Mar 2009
- Bittern
- 10
For the first time today I decided to explore thread cutting on my new (old) lathe. I attempted to cut M12 x 1.5, but the pitch spacing seemed way too close together? Can I kindly ask for advice here please? According to the front plate, (I think I'm reading it right) the right gear lever should be on "B", and the Left lever should be on "6". But the thread was way too close together! Please correct me If I am doing something wrong please! Then I thought maybe I don't have the correct gearing?
Which one is a stud gear (should be 45 tooth according to the plate)? and which one is the screw gear (should be 60 tooth according to the plate!
Any help would really be appreciated
with thanks
6th Nov 2021, 08:34 PM #2Most Valued Member
- 4,890
Your set up is correct, have you checked by measurement or with thread gauages?
6th Nov 2021, 10:08 PM #3Novice
- Mar 2009
- Bittern
- 10
thanks Pipeclay
Hi Pipeclay, thanks for your help I had to wait 15mins to login (it turned out being 30mins and new password, he he!).
No I just visually observed that it was way too small, at a guess it looked to be less than 0.5mm, perhaps 0.4mm between scratchings. Being my first attempt I slowed the machine and had the back gears engaged, I wonder, would this stuff up the pitch sizing?
7th Nov 2021, 09:10 AM #4Most Valued Member
Hopefully this pic adds some clarity. Can't help with the pitch issue though.
7th Nov 2021, 09:53 AM #5Most Valued Member
- 4,890
You could try as the above photo shows with the 18 on the stud and levers on A/4 to see if that gives a different result.
7th Nov 2021, 03:53 PM #6Novice
- Mar 2009
- Bittern
- 10
7th Nov 2021, 06:59 PM #7Member
- Nov 2015
- Brisbane Australia
- 85
Are you engaging the half nuts or are you winding the clutch in to engage the apron to move ?
To do thread cutting you need to engage the half nuts.
The apron has a inbuilt safety device so you can't use the clutch and the halfnuts at the same time.
When I use the halfnuts I leave them engaged all the time and use reverse on the motor to get the apron back to the starting point.
The alternative is to use a thread dial indicator.
Also do you know how to engage the back gears to make the lathe run slower?
7th Nov 2021, 08:09 PM #8Most Valued Member
7th Nov 2021, 08:16 PM #9Senior Member
- Aug 2015
- 240
You already have all the gears there, where the 45 tooth gear is now is the stud gear, that is to be swapped over with the 18 tooth gear that is on the gearbox when you use the lower chart on the gearbox plate, the link may help you out, it gives you the gear configurations for the lathes.
Standard gear configuration for Hercus 9" and 260 lathes
I put this together a while ago and I know it is not what you need but it may help you grasp changing gears, it shows changing the stud and screw gears although you only need to change the screw gear for imperial threads.
Compound gear configurations on 9" model A lathes
Hope that helps in some way.
8th Nov 2021, 08:06 PM #10Novice
- Mar 2009
- Bittern
- 10
Thanks for the information
Hi all just a quick note to say thanks for all the information, Late last night finally success! It was operator error (and lack of Lathe knowledge and no training). I wasn't engaging the apron nut . What I was doing was engaging the 3 position apron lever (not sure what that is called, someone please tell me!) and not the actual apron nut lever. so my pitch spacing went from photo 1 to photo 2. I was quite chuffed when it started to work! Admitidly rough as dogs balls but it is a step in the right direction
Thanks again everyone
8th Nov 2021, 08:15 PM #11Member
- Nov 2015
- 85
8th Nov 2021, 09:17 PM #12Novice
- Mar 2009
- Bittern
- 10
9th Nov 2021, 08:50 AM #13Most Valued Member
- 4,890
Seeing that you don't have a lot of experience, can I suggest if you have other problems or issues in the future that you try and explain in as much detail as possible what you are doing or did or what you were using, this would of made providing a solution to your threading issues much quicker.
Its always easier if the poster of a question always provides as much detailed information as possible, it saves all the backwards and forewords replies, a lot of times people just assume when replying to questions that there is some perceived knowledge.
9th Nov 2021, 09:50 PM #14Novice
- Mar 2009
- Bittern
- 10
Definitely will Pipeclay
Yes I will do that in future posts
thanks again.
260atm gearbox handle
By allterrain50 in forum THE HERCUS AREAReplies: 0Last Post: 28th Nov 2015, 12:21 PM -
Gears, gears and more gears
By .RC. in forum METALWORK GENERALReplies: 41Last Post: 22nd Jul 2014, 12:41 PM -
Gears for Hercus 260ATM
By bwal74 in forum THE HERCUS AREAReplies: 8Last Post: 10th Feb 2012, 02:06 PM -
Thread cutting on the 260ATM
By jack620 in forum THE HERCUS AREAReplies: 13Last Post: 31st Dec 2011, 05:31 PM -
Hercus 260ATM Install & Initial Setup Details Needed
By jackafrica in forum THE HERCUS AREAReplies: 10Last Post: 28th Sep 2009, 07:34 PM
