Results 1 to 14 of 14
    Jan 2009
    Holbrook, NSW
    73
    490
    Default saddle measurements
    Hi All,
    I need some additional data on the Hercus saddle dovetails. It seems that there is some differences in the dovetail width on the early Hercus 9's and the rest of the hercus 9 and 260's, up to about 0.035". This makes it hard to know which version to supply for the extended cross slide and thread stop. If I make them to fit all generations, there is a lot of unwanted space between the gib and the cross slide.
    I need owners of early model 9's, up to machine 8000, to take accurate measurements as per the attached pic.
    Oct 2004
    Southern Highlands NSW
    1,898
    I have Hercus 9A and 260 lathes.
    My 9 inch Hercus has serial no. A1578
    I measured at the front of the saddle dovetails.
    The 9A is about 0.015" wider than my 260 at the saddle dovetail.
    The cross slide on the 260 has also been used on the 9A. It was made as an aftermarket accessory for a Boxford lathe, and works fine on both my Hercus lathes.
    Jordan
    Addit: See other message below for corrections.
    Jan 2009
    Holbrook, NSW
    73
    490
    Default 3/8 guage
    Quote Originally Posted by nadroj View Post
    Jordan
    Hi Jordan,
    Thanks for that info, it tends to confirm the difference. Using a 1/2" guage however doesn't let me compare the actual dimension. Can you measure it with a 3/8 guage, which is what relates to one used in the Hercus drawing of the part.
    Mal
    Mar 2017
    65
    221
    Using 2 x 3/8 rods and a Starrett mic, I have the following results.
    S/n 911: 2.548"
    S/n 2100: 2.553"
    S/n 12065: 2.533"
    Surprised at the variation, although I did know that the after market T slotted cross slide I bought off you a few years ago would not fit on the 1943 machine, but fitted perfectly on the 1968 machine. I assumed a bit of work on the gib strip would have fixed it, but never tried. The 1943 machine now has the turret and cross slide attachments which fit perfectly. I reckon there is a slight difference in centre height off the saddle with the 1943 machine...but that might just be wear.
    Hope that helps, cheers, Tony
    Sent from my SM-N976B using Tapatalk
    Jan 2009
    Holbrook, NSW
    73
    490
    [QUOTE=Silversprings;1989610]Using 2 x 3/8 rods and a Starrett mic, I have the following results.
    S/n 911: 2.548"
    S/n 2100: 2.553"
    S/n 12065: 2.533"
    HI Tony,
    That's about what I was expecting. You are right about the gib, I supply a thinner one for the older machines, just trying to work out when they started making the thinner dovetail. At least we know, those up to 2100 had the wider one. Hopefully some of the others will confirm that.
    Mal
    Oct 2004
    1,898
    I misread the rod diameter as 1/2".
    These new measurements are with 3/8" drill bits.
    9" - 2.542"
    260 - 2.533"
    Jordan
    Aug 2019
    Revesby - Sydney Australia
    57
    1,196
    I couldn't find imperial precision ground round rod, and all my 3/8 drills are way undersize, but a few end mills were pretty good:
    Appears to be 2.528":
    but my 9 is a bit is a bastard; bed & gear cover are serial C7967, but tailstock says 6330;
    so who knows how old the carriage is
    Jan 2009
    Holbrook, NSW
    73
    490
    Default saddle
    Quote Originally Posted by nigelpearson View Post
    Thanks Nigel,
    That's about what I expected. Obviously need to look at much earlier machine numbers.
    Mal
    Sep 2009
    Sydney
    666
    Is my machine early enough Mal?
    Done have the required dowel pins but I need to grab some drills and sure I can cut one up to get the measurements. Need to measure them myself as I’m planning on scraping the wear out at some point.
    Jan 2009
    Holbrook, NSW
    73
    490
    Default saddle
    Quote Originally Posted by neevo View Post
    That is certainly early enough.
    Mal
    Sep 2009
    Sydney
    666
    Here’s mine Mal, not sure if I’m doing something wrong with the measurements but this is a lot more wear than I would have expected and hoped:
    My pins are also a fraction under size:
    2.564”
    Front to back:
    2.555”
    2.558”
    2.545”
    2.564”
    2.575”
    That low spot seems like a bit of an outlier but I’ve measured it loads of times. Wasn’t expecting 30 thousandths of wear and that possibly puts the scraping job a bit too far out of my reach.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Have you been able to determine if the wear is uniform on both sides?
    Sep 2009
    Sydney
    666
    How is it best to check that?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Having never had to do this I would think if you could source a piece of suitable material at the 3/8" diameter that is as long as the cross slide, you should be able to either eyeball a gap along the dovetail, or given the amount of wear you could check it with a feeler.
    You may even be able to use a straight edge if you can get it into a suitable position.
  1. Humidity measurements in compressed air
    By BobL in forum ELECTRICALS
    Last Post: 4th Jul 2020, 10:19 PM
  2. Sieg SX4 Mill Measurements
    By ronboult in forum METALWORK GENERAL
    Last Post: 24th Jun 2017, 11:26 AM
  3. Deciding when to be pedantic about measurements.
    By Mike4 in forum METALWORK GENERAL
    Last Post: 9th Oct 2016, 07:27 PM
  4. Taking measurements
    By Maxi77 in forum METALWORK GENERAL
    Last Post: 15th Sep 2014, 07:30 PM
  5. Leaf suspension measurements
    By murray44 in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 27th Dec 2012, 11:36 AM
