Results 1 to 3 of 3
27th Jun 2021, 02:23 AM #1Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,183
Cheap depth stop for your chuck/spindle
I was machining some spacers, and wanted an easy way to position them the same depth in the chuck jaws (for machining the parted-off side to length).
Looked at a few over-complicated in-spindle stops, decided that I didn't have time to make one that clamps/locks inside the spindle. So, looked around at my scrap for something to cobble together.
Amusingly, an old tap spindle is a close fit for the Hercus spindle:
Mount that in the chuck, ready for machining to spindle bore:
(as soon as I get those stringy spirals of swarf out of the QCTP).
It turns out that this spindle nut, er, spigot nut, doesn't have a single parallel axis in it. So, I re-grab in the threaded part (that I will be machining down), to machine the opposite side:
then I grab that now co-axial side, and machine the thread away to fit the spindle end:
tap it out to M12 coarse:
and put it on some threaded bar (that I occasionally use to bolt items onto/into the chuck):
I just shoved the bar+brass end down into the spindle, twisted the rod for the correct depth, and pushed the work piece against the other end of the threaded rod:
Turning the lathe on will unwind the threaded rod, so I just pull the whole thing out before machining anything.
As long as I didn't twist the rod too much, depth setting seems accurate to about 5 thou, but a few lock nuts help with that:
The long hex thing (a joiner) is just small enough to fit down the spindle. A standard M12 nut is not.
I also used a few of them to make the stop end larger than the bare M12 rod:
For this particular job, a chuck spider would have done the job, or external jaws in a small chuck. I also thought about using an old MT3 arbor:
and machining a thread or sliding stop into it (like this):
but I suspect the arbor is hard steel, and will be difficult to drill (and/or tap)Last edited by nigelpearson; 27th Jun 2021 at 02:31 AM. Reason: missing images
27th Jun 2021, 09:58 AM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
Thanks for that.
Is it that your work stop is not fixed to the spindle in any way, and used loose?
27th Jun 2021, 10:25 AM #3Diamond Member
- Aug 2019
- 56
- 1,183
Correct.
'tis just used for setting the piece in the chuck, and then slid out carefully before starting the lathe and making chips/swarf.
If I was leaving it in the spindle while machining, a few O-rings and/or some tape to make it a tighter fit would stop it rattling around?
stop 3 jaw chuck from jamming ?
By steamingbill in forum METALWORK GENERALReplies: 9Last Post: 28th Apr 2014, 06:28 AM -
chuck removal ..spindle old
By morrisman in forum METALWORK GENERALReplies: 22Last Post: 23rd Jan 2012, 05:23 PM -
Lathe spindle back stop
By Stustoys in forum METALWORK GENERALReplies: 30Last Post: 19th May 2011, 12:12 AM -
Depth-Stop for Elu Mitre-Saw...
By Batpig in forum METALWORK GENERALReplies: 0Last Post: 28th May 2009, 09:38 PM
