Results 1 to 2 of 2
Thread: Ball turning adapter.
26th Jun 2021, 01:53 AM #1Member
- May 2021
- australia
- 50
hey all, well i thought i might share what i done over the last couple of days.
I've wanted to get my ball/curve thing onto my lathe so i can do my shift knob
So first thing was to mock it up and see how i can get it to sit.
pretty damn close, and can shim it for a bit of height if needed.
this is the piece of random metal that i'll be using.
made it nice in the lathe, also yeah i know my tool wasn't perfectly centre :'( don't worry i ground it off nicely
making the other part of the adapter. I got the angle reversed on this one woops and had to make another haha.
fits into place nicely
drill a centre hole so i can plug weld it and aldo drill and tap the outer connecting holes for the bolts
Well, umm the weld even though it was nice didn't hold to the small circle piece, so i will just have to drill and tap it and hold it with another bolt.
198841930_499970941108673_714788608183743846_n.jpg199280575_334616091401572_5879176109515244359_n.jpg
Here's the circle piece, i've drilled, tapped and made clearance so the bolt head can be flush with the surface. I had to grind down the bolt head a little bit as i needed a 14mm drill bit and i only had a 13mm.
197162455_2594034634225971_6358005494229357378_n.jpg198133243_796323581022743_7368632091044933413_n.jpg
Here we have it all bolted together
and to the piece i'll be using it on first
and how it turned out
I know there's a little step, but sadly that's where the chuck jaws were holding onto the piece and i had to take 0.1mm off of the rest of the part to smoothe it out from previous mess ups.
Any ways, i hope you guys like this. Perhaps this will give someone else the idea if they get one of these ball turning things off of ebay. Mine's been sitting for a month now until today.
26th Jun 2021, 08:58 PM #2
Nice job, I really do need to make mine.
I do a a lot of weldments in my home shop.
For next time, if I was plug welding that I would have drilled a larger hole halfway down and made the pin around 3mm or so short of the surface.
Then pre heat it to take the cold out of it.
It doesn't need to be anywhere near red hot, just to hot to touch.
Slowly welding around the gap in a circular motion working your way to the centre to fill it up.
This way the weld gets between the pin and hole, the top of the pin and to the side wall of the hole.
When machined flat it has the strength to stay put.
Sent from my 5007U using TapatalkUsing Tapatalk
Ball Turning Simplified With The Aid Of Saddle Stops.
By Anorak Bob in forum METALWORK GENERALReplies: 5Last Post: 14th Mar 2018, 12:14 AM -
Ball turning attachment - operation of
By simonl in forum METALWORK GENERALReplies: 54Last Post: 26th Jul 2014, 12:27 PM -
Chronos Ball Turning Attachment
By bwal74 in forum METALWORK GENERALReplies: 0Last Post: 10th Nov 2013, 11:41 AM -
Ball Turning Tool
By Anorak Bob in forum METALWORK GENERALReplies: 86Last Post: 23rd Aug 2013, 04:22 PM -
Over The Top Ball Turning Tool
By seafurymike in forum METALWORK GENERALReplies: 5Last Post: 28th Oct 2010, 07:14 PM
