Results 1 to 10 of 10
24th Jun 2021, 03:51 PM #1
Cutting imperial threads on a metric 260
G’day Folks
I’ve been asked if I can help with a project that’s interstate and I’m trying to work out how I might go about it. It’s a “love job” so I don’t want to break the bank.
When I get there I won’t have access to all my usual tools. Most of what I will have should still be ok because apparently no-one has used them since I was last there. I can bring things with me of course but I don’t want to be carting too much around; certainly nothing I can’t lift myself.
One way to solve the issues involved will be to rebuild broken parts. However, some of these will have imperial threads and the lathe I know I will have easy access to will be a metric Hercus 260.
I was hoping someone here might be able to help me with some of the questions I have?
Are change gears available for the hercus 260 metric model to allow imperial thread cutting?
If so what range would they give?
What do they cost and where might I get them?
Assuming the machine is still up to spec is there any accuracy compromise involved?
Is there good reference material available on this that I could download (or purchase) so I can minimise the trial and error in setting up?
thanks to any who can assist!
horaldic
24th Jun 2021, 04:19 PM #2Most Valued Member
- 4,887
Do a search for Hercus thread chart, it will have the information you need.
24th Jun 2021, 04:20 PM #3Most Valued Member
They certainly are! https://australianmetalworkinghobbyi...product_id=175
pipeclay can explain how they are used. I wouldn't have clue.Chris
24th Jun 2021, 05:49 PM #4australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
threads
That will depend on which model 260 they have. ATM, BTM, CTM, DGM, etc. Different gears required for different models. What threads do you have to cut, no point spending more than you need on the gear set.
Mal.
24th Jun 2021, 07:25 PM #5Philomath in training
- 6,540
If you mention which 'interstate' you are going to, there may be a member who could assist and save you having to cart as much gear.
25th Jun 2021, 09:43 PM #6
ok, thanks, I spent a couple of hours going through the threads that came up in that search. I’m going to need to read them more than once I think. It’s not making a heap of sense yet!
I had a look at the metalworking hobbyist site too, thank you. So, I feel that the basic answer is yes. However, the arcanum of how to make the right levers do what I want isn’t quite there.
I can’t remember which 260 it is. Somewhere there’s an old photo so I’ll examine that.
I’d be in country Tasmania, about half an hour out of Devonport.
I’d like to be able to do this but I want to be absolutely certain that I will finish before I start!
26th Jun 2021, 02:26 AM #7australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
gearbox settings
If the machine is an ATM the gearbox handles and gears need to be set as follows, so the handles would be placed in the holes below column 2 for the lefthand handle and below B on the righthand handle.
26th Jun 2021, 02:48 AM #8australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
260atm
If you aren't familiar with the machine, this naming diagram will help.
26th Jun 2021, 10:32 AM #9Senior Member
- Aug 2015
- 239
Not sure if this is any help to you but I did this post with the lay out of the gears and the lever positions to hopefully take out some of the confusion when setting up compound gears for cutting the different metric on an imperial lathe or imperial on a metric lathe
Compound gear configurations on 9" model A lathes
It covers all model A lathes
26th Jun 2021, 05:20 PM #10
I know you want to go from metric to imperial but this video may help with using a thread chasing dial for metric to imperial or in the reverse.
metric thread cutting on old imperial (new visby) lathe??
By gpigeon in forum METALWORK GENERALReplies: 17Last Post: 12th Aug 2014, 03:13 PM -
Gear train to cut imperial threads on metric lathe (AL 340)
By 19brendan81 in forum METALWORK GENERALReplies: 11Last Post: 17th Jan 2012, 03:15 PM -
Cutting Metric Threads
By Abratool in forum THE HERCUS AREAReplies: 51Last Post: 2nd Oct 2011, 09:25 PM -
260 metric to imperial chart
By tanii51 in forum THE HERCUS AREAReplies: 3Last Post: 2nd Jun 2010, 02:50 PM -
Metric Thread Cutting on Model 9A with Imperial Lead Screw
By Rodd Perrin in forum THE HERCUS AREAReplies: 3Last Post: 21st Sep 2009, 02:14 PM
