Page 6 of 7 FirstFirst 1234567 LastLast
Results 76 to 90 of 95
  1. #76
    Jul 2008
    near Warragul, Victoria
    3,723
    Default pic
    The last pic with the dial indicator , the larger diameter looks to be a reasonably good finish for hot rolled . The brazed carbide tool you are using is not the ideal setup for a learner , it is probably the worst out of the three choices , HSS, carbide insert or brazed carbide. I would get rid of it . I think you would be far better off with a sharp HSS tool or a Aluminium style carbide insert with a sharp edge .
  2. #77
    Dec 2005
    South Australia
    1,657
    I have only just looked at this thread, I had the same problem when I bought my metal lathe over 20 yrs ago, I went through or same hair pulling, turned out to be a roll pin that locks the tool holder. the pin was slightly too small
    allowing the tool holder to move when in use, I replaced it with a tight fitting pin and the problem disappeared, have you checked that nothing is moving it is surprising what a very tiny movement can cause.
  3. #78
    May 2021
    australia
    50
    Quote Originally Posted by China View Post
    I'll go over it tomorrow and see what moving slightly
    I have noticed that the tool gets pushed back a little sometimes, but that's from the slack in the cross slide i believe ?
    edit:
    got these to try out as well
    I got these today. Going to have a play around some HSS blanks in a couple of sizes
    a right handed carbide holder with the blade things to go in
    and a few of the brazed carbide tipped ones.
    Also a little finishing stone for HSS and a steel shimming plate.
    I have a 2mm, 3mm and 4mm shimming plate along with various feeler gauge pieces to help where needed.
  4. #79
    Jun 2016
    Sydney
    283
    Default You can't
    I was using some degreaser spray as cutting fluid
    Well, that won't work! You need the opposite: a light oil would be a start.
    no idea how to get rid of these marks that are still present.
    There is only one way: do not put them there in the first place. Nothing else works.
    First of all, that steel looks pretty horrible for turning. Some steels are like that, including a lot of bolts. Might be good for something else. Get some free machining steel and see how that goes. Really.
    Check the tightness of the whole saddle: it looks as though it can wobble and let the tool dig in. If the saddle is too light, then you may not be able to prevent to prevent the wobble or chatter which gives those marks. That is a function of the lathe, and small old lathes are often looser than big new ones.
    If you must use that steel, you will need a sharp cow-mouth HSS tip (ie round), a high speed and a very fine cut - both in depth and feed.
    The path to learning is long.
    Roger
  5. #80
    Mar 2011
    Southern Flinders Ranges
    1,552
    If you decide to buy carbide, get positive rake tooling. I use CCMT and DCMT. I generally use a .4mm radius insert but I do keep .2mm radius inserts.
  6. #81
    May 2021
    australia
    50
    here's the latest all put together in a video
    https://www.youtube.com/watch?v=6Byn8lK-rvk
  7. #82
    Jun 2007
    sydney ( st marys )
    64
    4,890
    The hole in the tool holder should be a neater fit.
    The tool holder should be one piece not two as shown, you really should replace the 4 way.
    Has the compound always been loose as shown before you tightened it?
    Are there 2 small pins at the bottom of the holes that the screws on your crosslide screw into to hold the compound?
  8. #83
    Mar 2011
    1,552
    Yeah, sort out your slide and tool post before you start heading in any other direction.
    Mal at Australian Metalwork Hobbyist has spares and changeover bits, although I’d be tempted to look at a chinesium AXA (250-110/111) size quick change if you have budget for it.
  9. #84
    6,473
    Hi Mathu,
    Thanks for the video ! I noticed several things. First that tool holder needs to be properly sorted, the way its mounted is not good, too many interfacing layers that will allow movement.
    My top slide is secured into the cross slide in a very similar fashion. The pins that clamp the top slide on mine are machined at an angle that matches the taper at the bottom but do not close into the waist of the groove. This means that when the pinch bolts are tightened the top slide is firmly pulled down onto the top of the cross slide mounting face.
    When parting you should have the cutting/parting point as close to the chuck as is practicable. Whilst using a live centre to support the workpiece is OK, it can jam and break the blade, so if you have to provide support like that, then back the tailstock off just before you finish the cut.
    I made a new tool holder for my Myford lathe and got rid of the expensive QCTP and the four way tool holder in favour of a "Norman" patent one. I also made a similar one for a rear tool post, which I currently use for a parting tool blade.
    It would make a very good learning project for the lathe. I did a write up for it on here.
    https://metalworkforums.com/f303/t20...orman+toolpost
  10. #85
    May 2021
    australia
    50
    Thank you, Yes there are 2 pins there they are angle cut to fit with the compound slide insert.
    and yeah, when i took it apart i thought i would need another one, perhaps my one is home made 'shrugs' but it's the hole in the middle being too large for the bolt that makes me think i need another.
    Thank you. unsure which way i would go, 4 way post or a quick change due to the ability to change height of the tool with the qctp quite easily. But i've read 4 way is more rugged.
    Hi Mathu,
    yep, the pins are there for me as well and act the same way as far as i can tell.
    The parting tool, the point was closer to the surface that i wanted to be flat and not left with that tiny little nipple, that's all. The tail stock support i put in because i just rather have it and not need it than need it and not have it but i agree parting as close as feasible to the chuck is best
    I'll be doing more work tomorrow
    I don't have the coin to get a new post, but i know now that it's a likely cause of my frustrations.
  11. #86
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by mathuisella View Post
    QCTP every day of the week.
  12. #87
    Jun 2007
    sydney ( st marys )
    64
    4,890
    If you have a drill press or are able to drill holes accurately and some threading taps you can make your own 4 way post to suit what you want on the lathe, no milling required.
  13. #88
    6,473
    Hi Mathu,
  14. #89
    Jun 2016
    Sydney
    283
    Default Qctp
    My lathe came with a rocker, but I soon swapped a QCTP in place. Never looked back.
    So I bought a second QCTP, for the CNC lathe. Guess what: The tool holders are not strictly compatible between the two!
    Not a problem: a 0.8 mm shim down one or both angled sides on one unit makes it all perfect. For a given value of perfect. But they do work very well for me.
    Roger
  15. #90
    6,473
    Hi Rodger, Guys,
    I'm sure that you know my opinion about QCTP's ! They are great time savers in a production environment and I don't have a problem with that. But for hobbyists use they are an expensive toy !
    I got seduced by people telling me that they were better than sliced bread. To hell with the initial cost of the toolpost and all the tool holders you have to buy to keep up with the Joneses. I don't need or want to spend a small fortune on insert tooling just so that I can save the ten seconds that it takes me to change a tool, or the extra seconds that it takes to reset the tool height after I have just reground a tool.
    OK I'm a hobbyist and I take my time and think about what I'm doing, yes I make mistakes like anybody else ! At least my mistake doesn't cost production.
  1. hooray...finished
    By eskimo in forum GENERAL DISCUSSION / OFF TOPIC
    Last Post: 5th Nov 2017, 09:48 AM
  2. Repairs finished after a bad day.
    By Mike4 in forum METALWORK GENERAL
    Last Post: 12th Jul 2017, 09:56 AM
  3. Advice, tips re. removing duragal for a weld?
    By DoctorWu in forum METALWORK GENERAL
    Last Post: 19th Mar 2015, 10:50 PM
  4. Need advice making a small part
    By simonl in forum METALWORK GENERAL
    Last Post: 27th Nov 2013, 12:41 PM
  5. Finally Finished My 260
    By kwijibo99 in forum THE HERCUS AREA
    Last Post: 16th Apr 2010, 01:53 PM
