Results 1 to 11 of 11
    Jun 2014
    Adelaide
    9
    Default Metric Theading Hercus A
    Sure it's been covered and done to death, just can't find it.
    I have ALL the gears, as well as the handbook, but it STILL does my head in.
    Anyone here can point be to the relevant threads please?
    Thank you...
    Ian
    Oct 2004
    Southern Highlands NSW
    1,894
    We need a little more information to be able to help.
    Do you have a Hercus 9 inch or "260"?
    Does your lathe have a metric or imperial leadscrew?
    Jun 2014
    Adelaide
    9
    Quote Originally Posted by nadroj View Post
    Whoops... sorry! 9 Inch with the quick change gearbox. Imperial leadscrew.
    Jun 2014
    Adelaide
    9
    Quote Originally Posted by Ian Bee View Post
    What is confusing me, is the actual PLACEMENT of the 127 - 100 compound gear. A drawing or photograph would perhaps help.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    From the Hercus text book of turning
    Dec 2014
    Tasmania
    102
    I keep a copy of this handy by my lathe for this reason, the 2nd last page is what you need. (info for south bend but the same applies)
    ratters
    model-a-gears.pdf
    Aug 2015
    Adelaide
    239
    The 127/100 gears replace the 80 tooth idler, the 127 is driven from the stud gear and the 100 drives the 56 tooth gear on the gearbox, the 56 needs to be spaced out to allow contact with the 100, just need to swap the gears over on the gearbox input shaft, as in remove the 40 and 56 and reverse them, are the 127/100 already on a bush with a key? if not then they will need a keyed bush to rotate together to make the compound gearing work.
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Key would only be required if the compound gears are seperate, if the gears are bushed together. to form a non seperatable compound no key is required
    Jun 2014
    Adelaide
    9
    Quote Originally Posted by Tinkerer77 View Post
    Excellent! Thank you! My 127 and 100 are indeed separate. I will look into the bush arrangement,
    this now all makes sense... thank you!
    Jan 2009
    Holbrook, NSW
    73
    490
    Default 100/127
    100-127-gear.jpgThis is how my ones are put together if that will help.
    Jun 2014
    Adelaide
    9
    Quote Originally Posted by allterrain50 View Post
    Found the bushing, and have joined them! Now to cut some metric threads!
    Thank you to all...
    Ian.
  1. Hercus 9 metric leadscrew gear
    By allterrain50 in forum THE HERCUS AREA
    Last Post: 15th Sep 2016, 02:01 PM
  2. question about hercus 9a metric options
    By Justin Wright in forum THE HERCUS AREA
    Last Post: 29th Oct 2015, 10:09 AM
  3. Metric Hercus Model A
    By 1500king in forum THE HERCUS AREA
    Last Post: 21st Aug 2015, 09:32 AM
  4. Hercus Metric Question : Newbie
    By jmann_au in forum METALWORK GENERAL
    Last Post: 10th May 2013, 08:42 PM
  5. metric crossfeed nuts for Hercus 260
    By jack620 in forum THE HERCUS AREA
    Last Post: 1st May 2012, 05:34 PM
