Results 16 to 16 of 16
Thread: Setting a cutting angle question
24th Apr 2021, 06:54 PM #16Most Valued Member
- 4,890
As you have already noted the angle for offset threading does not need to be exact, if you have a protractor use that against the chuck, face plate or spindle set ata bit less than your desired angle and line your compound up with that, you will need to angle the protractor blade down to get it to align with the side of your compound, don't even be concerned that the side of your compound is not machined.
Very simple angle grinder cutting guide
By Tuomas Soikkeli in forum Members VideosReplies: 4Last Post: 21st May 2020, 05:21 PM -
Angle grinder cutting baseplate
By Grahame Collins in forum WELDINGReplies: 0Last Post: 28th Jun 2017, 10:23 PM -
DIY angle plate question
By Michael G in forum METALWORK GENERALReplies: 10Last Post: 9th Feb 2016, 09:13 PM -
Cutting metal - angle grinder/ cut off saw or both
By TomH in forum WELDINGReplies: 27Last Post: 20th Oct 2008, 09:04 PM
