Results 1 to 3 of 3
21st Apr 2021, 03:58 PM #1Member
- Oct 2019
- Nth Queensland
- 55
Model 0 Vertical Head bearing temp
I have dug up what previous threads I can on running temperatures of the bearings in the vertical head of Model 0 mill. It seems that they do run rather hot.
My question is while the temps noted in the threads may not be ideal, what are the limits? Given the Hercus Mills were designed the way they are, it would seem they have been operating at the temps they do since manufacture. At what point of temp should one worry?
My test run time of 5 mins @ 1400 rpm fro 35 to 41 C 10 minutes upto 43 c
TH
21st Apr 2021, 06:03 PM #2
Hi TH,
Whilst my mill is not a Hercus, it does use a pair of tapered bearings at each end of the spindle, they get warm but not hot ! It might pay you to strip clean and re-lubricate them. When I sorted mine out I used a lithium based wheel bearing grease, the old stuff was like a thick toffee making the spindle hard to turn by hand. Washing them out in white spirits cleaned them nicely.
Don't repack the bearings full ! Only about 50% is needed.
HTH.Best Regards:
22nd Apr 2021, 09:25 AM #3Member
- Oct 2019
- Nth Queensland
- 55
Thanx all have fesolved my query pls disregard post
Vertical head and tail stock Hercus model “O” wanted
By Ulfr in forum WANTED TO BUYReplies: 0Last Post: 3rd Jul 2020, 04:15 PM -
Rambaudi V2 vertical milling head
By Slatept in forum METALWORK GENERALReplies: 4Last Post: 21st Oct 2019, 10:17 PM -
Hercus Vertical Head.
By stix012 in forum THE HERCUS AREAReplies: 4Last Post: 12th May 2015, 08:05 AM -
Hercus Model O Vertical Head Clearance
By gdonald in forum THE HERCUS AREAReplies: 14Last Post: 16th Jun 2014, 08:45 AM -
What's in a vertical head?
By neksmerj in forum METALWORK GENERALReplies: 25Last Post: 19th Apr 2011, 05:11 PM
