Results 1 to 3 of 3
Thread: 90 tooth gear
    Aug 2012
    Greenmount, W.A.
    70
    274
    Default 90 tooth gear
    I am contemplating making a worm to mesh with Hercus gears (18 DP). I have been studying Ivan Law's book "Gears and Gear Cutting," and I have worked out that I need two 20 tooth gears, a 30 tooth gear, and a 90 tooth gear - to get the correct worm pitch. The first three I either have or can make from some disc brake rotors I have. They are really nice, and easy to machine - like cast iron, but I think they are probably a cast steel. For the 90 tooth gear I was considering making it from some marine grade aluminium (as I have a quantity of 10mm thick plate) or brass. 90 tooth gears are 5.111" OD, and I have this piece of round brass bar that is waiting to be transformed!
    I could make the gear from steel plate, but it occurred to me that brass or aluminium would be easier to machine, and would not blunt the involute cutters I have - as quickly as steel.
    The proposed 90 tooth gear won't get too much use - probably only once - unless I wreck the worm, and have to make a second one, or maybe a third one .... so I think either the brass or aluminium would be more than adequate for the job.
    Has anyone made gears from aluminium or brass?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Yes.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    Also yes.
  1. Gear tooth rounding
    By caskwarrior in forum METALWORK GENERAL
    Last Post: 6th Apr 2019, 09:15 AM
  2. 127 tooth gear
    By gpigeon in forum METALWORK GENERAL
    Last Post: 26th Mar 2012, 09:14 PM
  3. 28 tooth gear for al960
    By rfurzer in forum METALWORK GENERAL
    Last Post: 6th Feb 2011, 01:19 PM
  4. Hercus 127 tooth gear
    By bob colles in forum THE HERCUS AREA
    Last Post: 8th Jan 2011, 02:19 PM
  5. Gear tooth count on Back/Bull Gear.
    By pipeclay in forum THE HERCUS AREA
    Last Post: 6th Jan 2010, 11:56 AM
