Results 1 to 15 of 15
Thread: Ex Adelaide Uni Hercus Lathes
13th Mar 2021, 02:41 PM #1Senior Member
- Aug 2015
- 240
Hi all, this pair of long bed's popped up on Facebook marketplace the other night and a friend of mine sent me the link to them, there was only 1 photo of each lathe but they looked really clean, I contacted the advertiser who gave me the number of the guy who was actually selling them, I was really only interested in the Craftsman, kind of always wanted one as I personally think they are just a fantastic looking machine and very neat with everything tucked away and not a great deal come up for sale, anyway, I organised a time to view the Craftsman then the next morning contacted him again and asked to look at the 260 as well if there was no interest in it yet, I went to look at them and I just could not leave the 260 behind, for the price with everything it came with I decided to purchase both machines, I have now come to the conclusion I must be an addict or something, the person selling them told me his phone was going crazy and a few people wanted to get in before me and have a look, at least there are people around that stand by there word and still work on first to call, first in line. Plan with these is now to clean them up, put 240 motors on them and get them working, I have too many other projects to strip these down as well. The 260 came with the original build inspection record still attached in the back of the spare parts manual.
13th Mar 2021, 03:17 PM #2Most Valued Member
- 2,671
Very nice.
Unless you already have suitable 240v motors I’d seriously look at using a VFD instead of converting them. About $150 delivered for the EcoGoo 240-415v ones.
13th Mar 2021, 03:44 PM #3Member: Blue and white apron brigade
13th Mar 2021, 04:11 PM #4
If you're an addict, you're amongst friends! Wow, talk about being in the right place at the right time! Great pick up's, well done. Cheers, Tony (green with envy)
Sent from my SM-N976B using Tapatalk
13th Mar 2021, 05:50 PM #5Senior Member
- Aug 2015
- 240
Thanks for the heads up, I may look at that option, I have a VSD on a 9" and the good thing with that was it was a 2800rpm motor that i bought from a guy at work, it was all internal and I only needed to remote mount the pot, made for a good top end speed.
I have set up a late 260 with the 240v to 3 phase without VSD using a start and a run capacitor with a start cap timer, seemed to work alright but it never sounded nice on the start up, I think the start cap ran too long and I am talking as low a time as I could set the timer.
This is definitely a place for addicts of these things, my partner just rolls her eyes every time another 1 shows up, but I will confess, I am actually selling a couple off at the moment, one is advertised on gumtree but it kinda hurts to do that though .
13th Mar 2021, 10:10 PM #6Member: Blue and white apron brigade
4 pole (1440 rpm) motors give a wider practical speed range as most can run up to 125Hz (3500 rpm). When a 2 pole motor is used 125Hz is 7000 rpm - doubt whether most normal motors and bearings can cope with that long term.
15th Mar 2021, 08:28 AM #7Golden Member
- Vic
- 48
- 544
Congratulations, very very nice! It has extended cross slide, does it come with the taper turning attachment too?
15th Mar 2021, 11:46 AM #8Senior Member
- Aug 2015
- 240
26th Mar 2021, 12:22 PM #9Senior Member
- Aug 2015
- 240
I bought the vfd's
After giving it some thought and a little more research and probably just the fact I cannot be bothered changing motors on the new lathes and everything is already in place and I will not need to bore and re-key motor pulleys, I have ordered 2 x 240 to 415 EcoGoo VFD's. After talking to the electricians at work that have set a couple up and reading through what BobL and OxxandBert have said and posted across the forums amongst a few others, I decided to go with them, I will put up some photos as I go along and mount and wire them up, I look forward to the new challenge.
26th Mar 2021, 05:48 PM #10Senior Member
- Aug 2015
- 240
I was going through some photos and found a craftsman that I took some pictures of a few years ago in a guy's shed, the lathe originally came from the Flinders Uni down south of Adelaide, I am quite amazed at the number sequence here, AUL12728 and AUL12729
26th Mar 2021, 06:00 PM #11Diamond Member
- N.W.Tasmania
- 1,407
Government purchase order it seems, possibly a few more out there too in the same sequence. Is that the one you plan to keep? While not in the same class as other more industrial class lathes like a Colchester Chipmaster for example, you look to have two lathes in likely very good order, capable of a lot of good work for many years. Good decision to go with the V.F.D.s in my view, a little bit of work in the rewiring to do it right, but very beneficial in the end.
28th Mar 2021, 03:19 PM #12Senior Member
- Aug 2015
- 240
I will definitely be keeping both of these lathes, it's taken me a while to get my hands on the craftsman, I originally was not overly interested in the 260 but as soon as I saw it I just had to buy them both, the Hercus' will serve me well, they will do most of the work I need them to do and I have access to larger machines if I need them.
1st Apr 2021, 03:44 PM #13
1st Apr 2021, 05:18 PM #14Diamond Member
- N.W.Tasmania
- 1,407
27th Apr 2021, 11:03 PM #15Senior Member
- Aug 2015
- 240
VFD's have been fitted
I have put a post in the electrical section regarding the wiring of the VFD's, Unfortunately after the second unit was set up in the craftsman it decided to spark and crackle, it was running like a dream and then in standby mode it just went bang, must be a faulty capacitor I would think.
Hercus craftsman cabinet Adelaide
By Tinkerer77 in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 3rd Jan 2020, 08:44 PM -
Hercus Lathes
By whitem in forum THE HERCUS AREAReplies: 10Last Post: 2nd Jan 2013, 08:03 PM -
Hercus Lathes
By whitem in forum THE HERCUS AREAReplies: 19Last Post: 14th Dec 2012, 02:33 PM -
Hercus Lathes.
By bob colles in forum METALWORK GENERALReplies: 5Last Post: 29th Jul 2012, 04:35 PM -
10 Hercus lathes for sale in Adelaide - $950
By jmk89 in forum THE HERCUS AREAReplies: 18Last Post: 9th Oct 2008, 10:55 PM
