Results 1 to 4 of 4
    Jan 2012
    Victoria
    3
    Default Hercus Model A 9" gear set
    My apologies if already covered but I can't find what I need.
    I have a Hercus Model A 9" with a quick change box.
    Most of the change gears are missing.
    Can anyone tell me how many gears are in a standards set and what the tooth counts are please.
    A photo of a standard set up on the lathe would be most appreciated.
    Aug 2015
    Adelaide
    240
    On the standard set up there is a 20 or 40 tooth gear (depending on which feed/screw cutting rate you are using from the gearbox plate) for the gear that drives from the reversing tumbler with then drives an 80 tooth idler gear to a 56 tooth gear on the gearbox.
    You should have a 40 tooth gear on the gearbox which interchanges with the 20 tooth gear.
    The attached pic may help understand what i am talking about.
    If you were talking about the gears for cutting metric threads then there is a totally different set of gears for that.
    Regards Steve
    Aug 2015
    Adelaide
    240
    This might be a better description for you with these pics.
    May 2004
    Melbourne Australia
    60
    37
    K
    M
    L m
    Quote Originally Posted by Tonyau View Post
    Sent from my SM-G960F using Tapatalk
  1. Hercus model "O"
    By Ulfr in forum THE HERCUS AREA
    Last Post: 23rd Oct 2020, 11:03 PM
  2. Hercus Model A Gear
    By anj909 in forum THE HERCUS AREA
    Last Post: 12th Feb 2015, 09:58 PM
  3. hercus 9" c model
    By tryhard202 in forum THE HERCUS AREA
    Last Post: 4th Nov 2012, 11:43 PM
  4. Hercus 9" Change Gear Set For Sale
    By checkyoursix in forum THE HERCUS AREA
    Last Post: 7th Jan 2012, 02:04 PM
  5. Hercus Model A Bull Gear
    By YarrD in forum THE HERCUS AREA
    Last Post: 23rd Jan 2010, 08:17 PM
