Results 1 to 15 of 41
Thread: Rotary table for O mill
3rd Feb 2021, 06:34 PM #1Senior Member
- Aug 2015
- 239
Hi All
I have an Uncle that showed me some incomplete rotary tables for the O mill that he had purchased from Hercus when they were selling off their remaining parts many years ago, they are missing the worm drives and all of the parts for the handle and dividing plate but they have the body, table , driven worm ring and the bottom retaining plate.
My question is, would there be anyone out there that has one of these that they would be willing to lend me at some point so I could make the missing parts for them, preferably in Adelaide.
Cheers Steve
3rd Feb 2021, 06:59 PM #2Philomath in training
- 6,541
Interesting project Steve. I haven't got a Hercus R/T but would be willing to help nut out what the parts would look like - one of my dividing heads is probably about the same vintage and the handle looks similar to your pic. The worm is probably just a matter of measuring and working through some ratios.
3rd Feb 2021, 08:33 PM #3Senior Member
- Aug 2015
- 239
Thanks Michael
I was going to grab one next time I see him and see what is actually involved, I do have a small dividing head in the shed, I was thinking about working out some details off that, try to work out and transpose the dimensions in to something that would work, just need to work out the ratio I guess, I would assume maybe 90:1 might be the right one for that, handles and the dividing plates are an easy part to make, it's always easier when there is one to copy.
5th Feb 2021, 08:22 PM #4Golden Member
- Oct 2001
- ACT
- 667
one of the hercus rotary tables would be nice.
according to the manual, the ratio for the rotary table was 80:1 and quote that it was twice the ratio of the dividing head
2nd Jun 2021, 10:38 PM #5Senior Member
- Aug 2015
- 239
14th Jul 2021, 02:15 PM #6Senior Member
- Aug 2015
- 239
The rotary table base, table, gear and retaining plate, They seem to be for the 2 slot tables with the bolt spacing.
15th Jul 2021, 12:09 PM #7.
- 6,458
I might be able to help you Steve. Back in 2005 Steve Durden sent me some No.O parts and included was a base casting and a worm spindle for the rotary table. With the exception of the worm and worm wheel, the division plates and the ball handle, I made the missing parts. The worm and worm wheel were purchased from HPC Gears in Chesterfield, England. I had previously purchased the gears for the little Hercus dividing head from HPC and they worked and still work well.
When I made the table it was based on a low resolution catalogue photo in which the slots appear to stop short of the centre bore. I subsequently found out that they run into the bore which would be far more convenient than stopped slots.
I have never used the indexing attachment on the table. The ball handle is far easier to use to rotate the handle than the spring loaded detent on the indexer. The collar is graduated in two rows to provide nine degrees in two revolutions. I have a six inch Vertex rotary table that I very seldom use. The little Hercus has proven an invaluable accessory on both my mills.
IMG_20191124_142603881.jpg IMG_20191124_140525761.jpg IMG_20191124_140338013.jpg IMG_20210506_130815583.jpg IMG_20210506_141245762.jpg
Bob.
15th Jul 2021, 01:59 PM #8Golden Member
- Oct 2001
- ACT
- 667
Thanks for the pictures Bob,
Any chance of pictures of the left side where the locking mechanism is? (I assume its similar construction to the dividing head with a split cotter type lock)
I assume it also has an eccentric mount for the worm wheel? does that go all the way through or is it only supported from the front side.
15th Jul 2021, 06:57 PM #9Philomath in training
- 6,541
If you can't manage it on your equipment if I had the dimensions I could probably do the worm for you...
15th Jul 2021, 08:12 PM #10Senior Member
- Aug 2015
- 239
Thank you Bob, I was working off of the catalogue pictures as well, not the easiest way to work it out but when thats all there is then thats the best we have.
Thank you Michael, that is very generous of you, I have never needed to machine a worm spindle so help would be appreciated, I know our lathes at work are capable of cutting worms but whether they have the tooling for cutting it is a different story.
15th Jul 2021, 08:43 PM #11Senior Member
- Aug 2015
- 239
There is a couple more close up photos of the body, for some reason a few of the better pics would not upload.
15th Jul 2021, 08:55 PM #12.
- 6,458
Mine apart.
IMG_20210715_140531521.jpg IMG_20210715_141159701.jpg IMG_20210715_142035544.jpg IMG_20210715_142111574.jpg IMG_20210715_142628015.jpg IMG_20210715_142745213.jpg
IMG_20210715_142810050.jpg IMG_20210715_142942961.jpg IMG_20210715_142836977.jpg IMG_20210715_143217378.jpg IMG_20210715_144239497.jpg IMG_20210715_144319773.jpg
IMG_20210715_144545330.jpg IMG_20210715_144816761.jpg IMG_20210715_144944048.jpg IMG_20210715_145421137.jpg
The worm is 1 start 24DP, 0.1309" pitch with a lead angle of 3 degrees 48 minutes. The HPC Gears part no. is W24-1. The 80 tooth worm wheel has a pitch diameter of 3.333". The part no. is M24-80.
15th Jul 2021, 09:50 PM #13Philomath in training
- 6,541
Beaut pictures as always Bob. Just looking at the worm - not very big! Still, I have a ratio for that circular pitch so cutting is not an issue.
For those who haven't cut worms before, it's not that much different from cutting a thread. The main change is that Pi is involved, so the pitch is something odd. In this case 0.1309", which works out to 7.64 tpi. Unless you have a flash lathe with these things built in, it usually means change gears - in my case 56:66 to change what the QC gearbox thinks is a 9tpi thread into 7.64tpi at the tool.
15th Jul 2021, 11:39 PM #14Golden Member
- Oct 2001
- ACT
- 667
Thanks for going to the trouble taking that apart and photographing, thats awesome.
While what you bought is 80:1, any idea if the worm/worm wheel is the same DP as Tinkerer77s parts? not a lot of space inside there, could be the same?
any idea on the amount of offset on the eccentric for the worm? doesn't appear to be a lot, guess it just needs to be enough to disengage.
16th Jul 2021, 11:33 AM #15.
- 6,458
Steve,
I'm pretty sure I would have discussed the issue of gearing of the table with Steve Durden at the time and 24 DP fits, 20 DP is too big, an 80 tooth wheel has a PCD of 4.000". The bore of the table is only 3.5"
The dismantling came at a cost. When I reassembled the thing I was trying to position the eccentric to provide the minimum of backlash without binding. The 1/4" screw that secures the eccentric clamp tore out the cast iron . My fault because the screw should have been longer. Anyway there was sufficient material between the bottom of the threaded hole and the base to enable the drilling and tapping of a through hole and the fitting of a proper screw. Just something to be aware of.
IMG_20210715_160034802.jpg IMG_20210715_161713991.jpg IMG_20210715_162935355.jpg IMG_20210715_165632306.jpg
I said to Steve 'Tinkerer" that I would measure and draw the eccentric and the shaft for the worm.
BT
Rotary Table ID
By bollie7 in forum METALWORK GENERALReplies: 1Last Post: 15th Jan 2019, 11:07 PM -
WTB Rotary table
By KBs PensNmore in forum WANTED TO BUYReplies: 0Last Post: 17th Nov 2018, 11:57 PM -
Mini Mill owner who also have a Rotary Table
By Jim Ferrous in forum METALWORK GENERALReplies: 10Last Post: 21st Oct 2013, 12:30 PM -
Which rotary table for your X2 Mill
By Big Shed in forum METALWORK GENERALReplies: 3Last Post: 1st Oct 2009, 08:39 AM -
Rotary Table
By graemet in forum METALWORK GENERALReplies: 26Last Post: 8th Oct 2008, 09:34 AM
