Results 16 to 21 of 21
Thread: Thread chart, help needed.
24th Dec 2020, 12:02 PM #16Most Valued Member
- 4,887
If the thread you cut was not 1.5 but what was set on the gearbox you may not of been able to drop in anywhere.
Sent from my T85 using Tapatalk
26th Dec 2020, 06:07 PM #17
Success!
But I can't figure out what caused the problems before except your suggestion, Pipeclay.
But that means I had something askew in my settings because this time I still just dropped in without reference to the thread dial and I did open the halfnuts at the shoulder.
Thanks to those who posted suggestions and all the best for the New Year.
31st Dec 2020, 12:13 PM #18
Task complete, finally finished the caps to go with them.
Actually, it was learning exercise cutting an internal thread into a blind hole and finishing the outside.
31st Dec 2020, 09:26 PM #19
Hi Boris, Guys,
If the thread being cut is a multiple of the leadscrew then you can drop in anywhere ! This applies to an imperial machine and I assume metric as well.
Cutting threads in a blind hole, its safer to cut from the inside out away from the chuck.
Anyway from the pictures it looks to be all good.Best Regards:
1st Jan 2021, 04:08 PM #20Most Valued Member
Nice job.
2nd Jan 2021, 08:25 AM #21australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
quite correct, the line was repositioned later, as shown on the current new plates.
Imperial and Metric Bolt Thread and Torque Chart
By moorebrm in forum METALWORK GENERALReplies: 5Last Post: 31st May 2016, 01:48 AM -
Printable imperial-metric-bolt-thread-torque-chart
By moorebrm in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 16th May 2016, 09:03 PM -
Gas Thread info needed
By ericg in forum METALWORK GENERALReplies: 5Last Post: 12th Jan 2015, 01:31 PM -
ACME thread chart
By morrisman in forum METALWORK GENERALReplies: 1Last Post: 7th Aug 2012, 09:48 PM -
AL-340A Thread Chart Misprint
By matthew_g in forum METALWORK GENERALReplies: 1Last Post: 12th Jul 2010, 08:32 AM
