Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Jun 2007
    sydney ( st marys )
    64
    4,887
    If the thread you cut was not 1.5 but what was set on the gearbox you may not of been able to drop in anywhere.
    Sent from my T85 using Tapatalk
  2. #17
    Mar 2017
    Sydney between denial & paranoia
    88
    Success!
    But I can't figure out what caused the problems before except your suggestion, Pipeclay.
    But that means I had something askew in my settings because this time I still just dropped in without reference to the thread dial and I did open the halfnuts at the shoulder.
    Thanks to those who posted suggestions and all the best for the New Year.
  3. #18
    Mar 2017
    88
    Task complete, finally finished the caps to go with them.
    Actually, it was learning exercise cutting an internal thread into a blind hole and finishing the outside.
  4. #19
    6,439
    Hi Boris, Guys,
    If the thread being cut is a multiple of the leadscrew then you can drop in anywhere ! This applies to an imperial machine and I assume metric as well.
    Cutting threads in a blind hole, its safer to cut from the inside out away from the chuck.
    Anyway from the pictures it looks to be all good.
  5. #20
    Nov 2007
    melbourne australia
    3,228
    Nice job.
  6. #21
    Jan 2009
    Holbrook, NSW
    73
    490
    I've always believed the line between the 18 and 45 is in the wrong place, because there's no way you could get the same thread pitch with two different gears and with the levers in the same positions. I reckon that line should be in line with the line below the "B".
    quite correct, the line was repositioned later, as shown on the current new plates.
  1. Imperial and Metric Bolt Thread and Torque Chart
    By moorebrm in forum METALWORK GENERAL
    Last Post: 31st May 2016, 01:48 AM
  2. Printable imperial-metric-bolt-thread-torque-chart
    By moorebrm in forum CONVERSIONS & CALCULATIONS
    Last Post: 16th May 2016, 09:03 PM
  3. Gas Thread info needed
    By ericg in forum METALWORK GENERAL
    Last Post: 12th Jan 2015, 01:31 PM
  4. ACME thread chart
    Last Post: 7th Aug 2012, 09:48 PM
  5. AL-340A Thread Chart Misprint
    By matthew_g in forum METALWORK GENERAL
    Last Post: 12th Jul 2010, 08:32 AM
