Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Aug 2016
    Adelaide
    80
    Default Hercus vibration when running
    Does anyone else with hercus 260 get vibration when running at different speeds? When I vary the speed there are some points where I get a lot of vibration coming from spindle drive, enough to shack the lathe. This is without taking a cut. The lathe is on the original stand and it's well leveled.
    Not sure of the cause yet but I guess it from unbalance pulleys or motor?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Have you checked the bearings?
    Aug 2016
    Adelaide
    80
    Spindle, counter shaft and motor all spin freely. At low speed the vibration is hardly noticeable. I would say the vibration is not high frequency, more of a resonant wobble.
    7,189
    Have you checked Motor with nothing attached and then systematically added other rotational components?
    Aug 2016
    Adelaide
    80
    No, not yet. I'll try narrow it down tonight. I'd be interested to know if this is common problem amongst other owners.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Seeing that it doesn't appear to be a type of reoccurring question, I would hazard a guess and say not common, that being said 260 owners may not like sharing common faults.
    Sep 2006
    Australind , WA
    58
    1,281
    If a lathe has been sitting for a whle, the drive belts can develop 'knobs' where they sat on the pulleys.
    I fitted 'Link belts' to my lathe ( not a 260 ) and immediately noticed an improvement in smoothness.
    Even if that is not your problem, I'm sure you will like the change.
    Aug 2015
    Adelaide
    240
    Do you have a VSD fitted? Sometimes they can make the motors vibrate and hum.
    Nov 2015
    Brisbane Australia
    85
    Is the machine level?
    Where the cabinet /feet contacts the ground is the four corners supported well.
    I had it once with mine, one of the feet at the tailstock end did not have a lot of weight on it and it would move/ bounce at certain speeds.
    I bolted my stand on 100mm square tube and put adjustable feet on this.
    I wanted the lathe to be higher, I don't have "ducks disease" ( too close to the ground.)
    The concrete I have the lathe sitting on is not thick enough to bolt it to the floor.
    6,480
    Hi Simon,
    My Myford cabinet, is sheet steel, it sometimes vibrates at a particular motor speed depending on how heavy a cut I'm taking. The steel backsplash doesn't help because it is fastened to the wall and sits on the drip tray lip. So when it does vibrate it get amplified by the backsplash. Unfortunately I cannot move it because it has a hole in it that sits tight around the light switch.
    The other thing is that the rubber motor mounts are deteriorating allowing the motor to move more particularly when starting. I really need to get some new ones and fit them.
    I can confirm that single phase motors do vibrate far more than three phase ones do. I've threatened for years to fit a three phase motor and VFD, I even purchased a brand new "Brooks" motor just before they shut the Huddersfield factory, so you can tell how long I've had that motor sat. Must be getting on for twenty years.
    Aug 2016
    Adelaide
    80
    I have levelled the lathe on a fabricated platform with feet. I did it like this so I could swap the feet for casters and move it around. Perhaps the stand and platform are not as rigid as I thought they would be, but the cause seems to be the counter shaft assembly. The pulley driven by the motor has a bit of wobble. I ran the motor alone and it seemed fine. Then, the motor + counter shaft and it produced the wobble. The pulley bore and shaft fit could be tighter I think, the grub screw seems to tilt the pulley a bit. Balance might be out too. I'll start by trying to improve the alignment and balance of the counter shaft and pulleys, hopefully I can reduce the wobble. BTW, I am running a VFD.
    6,480
    Hi Monchochos,
    If there is only one grubscrew in the pulley, it might pay you to put another two in at 120 degrees from each other. If you then go round and tighten each one in turn you should find a point where the runout is minimised. It all depends upon how loose or tight the bore is on the shaft.
    If its a loose fit then the three grub screws will tend to push it straight, if its a tight bore then the pulley bore has been machined slightly askew and will need boring out and a sleeve pressing in then boring to size.
    If it still vibrates after that, then only balancing will improve it !
    Aug 2016
    Adelaide
    80
    Thanks Baronj, good suggestion with the extra screws.
    near Rockhampton
    6,218
    Take the chuck off and try it?
  15. #15
    6,480
    Quote Originally Posted by monchochos View Post
    Another thing you could check is if the bore of the pulley and rim are concentric !
    The way the counter shaft is situated on those lathes an off centre pulley will cause vibrations.
  1. Bench grinder vibration
    By ptrott in forum METALWORK GENERAL
    Last Post: 26th Dec 2019, 10:28 AM
  2. Hercus 260 Running in Reverse
    By turbodude in forum THE HERCUS AREA
    Last Post: 1st Aug 2013, 09:28 AM
  3. vibration during turning
    By jack620 in forum METALWORK GENERAL
    Last Post: 7th Nov 2012, 12:08 PM
  4. Dial Indicators, Vibration & Damping
    Last Post: 13th Apr 2011, 08:52 PM
  5. Vibration While Boring after reasons why
    By pipeclay in forum METALWORK GENERAL
    Last Post: 11th Oct 2007, 08:11 PM
