Results 1 to 14 of 14
    Sep 2020
    Terrigal
    46
    4
    Default Hercus 260 quick change tool post and tool size
    Hi guys,
    I’m pretty new to all this, so apologies if I use incorrect terminology.
    I’ve just bought a Hercus 260atm and I’m going to install a QCTP. I’m thinking I might get the one from Ausee Machinery linked below, but it’ll only take 12mm tools. I was hoping, however, to use indexed tools with a 16mm shank; I’m not sure why, I just thought the larger shank would be more rigid and provide a better cut.
    My question is; is there any issue with using 12mm tools or should I look for tool holders that’ll accept a larger shank? What size is best for the Hercus 260?
    The measurement from the Centre of chuck to compound slide is 30mm so I’m pretty sure the Hercus will accept larger tools.
    Thanks for any advice,
    Shaun.
    https://www.ausee.com.au/shop/item.aspx?itemid=4249
    Jan 2004
    Mackay North Qld
    6,446
    Hi Shaun and welcome to the forum.
    I am not saying for sure but hazard a guess and would say the 260 in the Hercus Model name means 260mm swing or 10 3/8".
    If so, a larger tool post would suit the 260 hercus
    https://www.ausee.com.au/shop/item.aspx?itemid=4252
    read down that page for info on sizing
    The problem is that the toolpost would fit but at the same time it is also made to fit fit larger lathes.
    I would question if the Hercus 260 is substantial heavy enough to endure the load that COULD be placed on it.
    I only had a a few hours on a Hercus 260 so I don't feel able to advise on aspect. However some Hercus owners will be along soon enough.
    To help explore the areas of our forum here's a guide on to to navigate our Forum and find all the goodies.
    Goto the FORUM box in the top left hand cnr of the page and click the down arrow. This will bring up a pull down menu that has Forum Home at the top
    Click Forum Home which will present a scroll down page.
    Our rules,the Terms of Service are right at the top ,we encourage you to read them.
    Below that are all the various areas and sub forums that make up our MetalWork forums.
    If you want to post pics in your first ten posts sometimes our moderation kicks in, so at times I may have to moderate them manually.
    Welcome
    Nov 2007
    melbourne australia
    3,228
    Welcome.
    12mm tools are fine, but 16mm holders give you more options. You can buy 16mm holders. I have plenty of them. Look for AXA 250-101XL.
    It would be worth confirming that the set in question it compatible with an Aloris AXA QCTP. If so, AXA tool holders from any supplier will fit.
    I notice Ausee is out of stock.
    Sep 2020
    Terrigal
    46
    4
    Oh no, I didn’t notice they were out of stock! I was hoping to order them tonight.…
    I might have to get a decent quality one. Any suggestions? And what does AXA relate to? Is it a standard or a brand name…?
    Thanks for the replies.
    Nov 2007
    melbourne australia
    3,228
    AXA is the size. This might be another option. http://mag-pro.com.au/goods.php?id=221
    His postage through the website is extortionate. Apparently you will get a better deal on postage if you email him. I think he also has the 16mm holders. I haven’t bought from him, but other people on the forum reckon he’s OK.
    Decent quality? Well other than the Chinese ones, your options are genuine US made Aloris or Dorian. I have an Aloris AXA size QCTP, but I use Chinese holders. I can’t see the value in the genuine holders. The Aloris QCTP is lovely.
    May 2020
    ACT
    27
    I agree Chris. I have an AXA (250-100) copy from OZMESTORE on eBay on mine. Best deal I could find on them during these covid times of slow boats from China. I think the BXA (250-200) would be too big for the 260, they are significantly bigger than the AXA.
    The 250-101XL toolholder are the go. Harder to find though. The other option to to use a mill if you have one and make the opening a little larger on the standard tool holders as long as it still has enough rigidity with the remaining material.
    Craig.
    Sep 2020
    Terrigal
    46
    4
    Yeah, I ordered from M&G because his website said they were in stock, but I received an email stating he’d contact me when they arrived. I might just bite the bullet and order an Aloris and use aftermarket holders. Or I spoke to Mal today and he’ll have some in December that include the tool post stud which would be good.…
    Mar 2011
    Southern Flinders Ranges
    1,555
    I just bought a 250-111 tool post from the US because no one here had one in stock. About $110 for the post and around $50 in freight and duty. Worked out about a third of the price of a genuine Aloris.
    https://allindustrial.com/all-indust...older-250-111/
    Sep 2020
    Terrigal
    46
    4
    I just ended up buying an Aloris with two tool holders from the same site. The dollar was like 67c or something too…🙄
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by Shaun@27 View Post
    Geez that annoys me. It's happened to me three times in the last two months.
    Jan 2009
    Holbrook, NSW
    73
    490
    Default 16mm tool holders
    Excuse my late reply to this post and the blattent advertising. Apart from a more rigid 16mm boring bar (which you can't use in tight bores), I can't really see the point of using larger than 12mm. The kind of cuts requiring more rigid tools aren't within the capacity of the Hercus machines. You need to remember these machines originally used 1/4" HSS tools quite efficiently. If you had a machine capable of 12mm cuts, I could see the point but the extra cost of the larger tooling seems like a waste. Even my heavy Index-Werke cam auto, making fairly heavy cuts, only uses 8mm tool steel. I have added the 12mm version of the AXA-100 (piston style) to the AMH website again, after several years without it, this is the correct size for the machine, the BXA-200 is too big for the Hercus. I use the same tool post on all my Hercus 9 and 260 lathes.
    https://australianmetalworkinghobbyi...product_id=893
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by allterrain50 View Post
    ... the axa-200 is too big for the Hercus.
    Did you mean BXA-200 Mal?
    Jan 2009
    Holbrook, NSW
    73
    490
    sure did, corrected, thanks Chris
    Dec 2008
    Corndale
    212
    Haven't been here for a long time but for my two bobs worth the 12mm holders are fine.
    I use mostly CCMT/CCGT 0602 inserts for steel, aluminium and brass etc and have no problems.
    The trick is to learn what inserts to use and practice to get the feed and speed right.Preferably before you get to the last cut on the job.
    Micheal.
  1. Quick Change Tool Post for Hercus 260
    By justask4 in forum METALWORK GENERAL
    Last Post: 19th Nov 2019, 12:03 PM
  2. Tooling size with quick change tool post.
    By Arty Marty in forum METALWORK GENERAL
    Last Post: 31st Aug 2019, 01:39 AM
  3. wanted quick change tool post 250.202 size
    By Gravel in forum WANTED TO BUY
    Last Post: 30th Jan 2019, 06:26 PM
  4. Hercus 260 Quick Change Tool Post size
    By localele in forum THE HERCUS AREA
    Last Post: 31st Oct 2015, 05:43 PM
  5. Replies: 3
    Last Post: 15th Dec 2014, 07:45 PM
