Results 1 to 13 of 13
    May 2013
    close
    24
    Default Headstock Removal on model c
    I went to remove the headstock on my model c with cast iron bearings today.
    I did a lot of reading about the method and was prepared with a hammer and hardwood.
    I did everything suggested but when I went to knock the headstock out, it came out with a bump of the hand?
    I checked all surfaces and they all look good.
    It does leak oil from the front bearing though.
    Did I just get lucky with the removal or would it be because of wear?
    It snugs back up nicely and seemed to run nice and true whilst not getting hot.
    Andrew.
    Sep 2009
    Sydney
    666
    Not sure. Mine was not that easy to take out but some gentle repeated taps with a plastic hammer was all it took to remove.
    Have you measured the spindle play with it back together?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Some of it will be dependent on how tight the spindle is through the Bull gear.
    May 2013
    close
    24
    Quote Originally Posted by neevo View Post
    I will put the indicator on it on the weekend.
    I am quite new to metal work and am taking my time learning all I can.
    Should I be checking with a 25mm bar?
    May 2013
    close
    24
    It feels ok but definitely not a press fit.
    Sep 2009
    Sydney
    666
    Quote Originally Posted by trail View Post
    I out put a length of copper pipe in the spindle about 500mm beyond the end of the spindle and pushed down and pulled up with reasonable force. Got 0.004mm with mine which is just about at max spec I think.
    Mine needs to be reduced a bit but it only really shows as a problem when taking heavy cuts. My max cuts generally are 0.025” which is more than enough for what I do.
    May 2013
    close
    24
    Thank you for your reply.
    I'll try this and see what I end up with.
    The rest of the machine was covered in chips with some good wear in places.
    I'm expecting some play.
    Fingers crossed not too much.
    May 2013
    close
    24
    I checked with a bar and dial indicator.
    I'm getting 0.04mm front and back.
    I'm not leaking from the rear bearing but the front is.
    Can anyone please advise on the acceptable tolerance on the cast iron bearings?
    Sep 2009
    Sydney
    666
    I think that’s the top end of clearance as 15 thousandths is considered top end I think.
    Easy to remove the shim pack, take out a thin shim and replace with something suitable to get back to spec.
    I will likely aim for 0.02mm when I do mine. Tighten the bolts on the head so it gets warm but not hot.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Wouldn't worry to much if you have oil leaking from the front and there will be all leaking from the rear.
    Can you explain what you meant front and back? You generally test in the vertical position.
    Generally, .0005" to .0015" should be a reasonable clearance, by no means adjust to remove all leaking oil.
    May 2013
    close
    24
    Thank you.
    I'll aim for in between the two and put in some new wicks.
    May 2013
    close
    24
    By front and back, I just meant I extended the bar out the chuck side of the spindle, checked the measurements, then extended out the other and checked.
    All up and down movements with the bar.
    I wasn't very clear with my description.
    I won't bother with all oil leaks but i found it had no wicks in a lot of it.
    That might help.
    Sep 2009
    Sydney
    666
    Mine does exactly the same btw. Runs out the front bearing and can’t see where it’s running out the rear Headstock Removal on model c
    I just keep it topped up all the time.
    Also means it’s always oily so I wipe the machine with a rag and spread it around. I call it a “feature”... spindle lubrication and machine rust prevention.
  1. Replies: 10
    Last Post: 15th Mar 2019, 07:52 PM
  2. Model A Apron on Model C Hercus Lathe?
    By TommyGMachining in forum THE HERCUS AREA
    Last Post: 17th Dec 2018, 09:11 AM
  3. Magazines in need of a home - Aust Model Eng, Model Eng, Model Eng workshop
    By DarrylB in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 7th Mar 2018, 06:20 PM
  4. Model Engineer & Model Engineers' Workshop Magazines - FREE
    By John T K in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 23rd Jan 2018, 09:26 PM
  5. Sheraton Model AM Spindle removal?
    By Com_VC in forum THE HERCUS AREA
    Last Post: 14th Apr 2011, 06:02 PM
