Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    Apr 2015
    Sydney, Australia
    23
    Default Is there a brand of DRO that is suited to a 1960's Hercus Lathe?
    Hi folks,
    I have been trying to use what I have in my workshop a little better and hence the inquiry of fitting a Digital Readout to the little Hercus lathe.
    Is there a model / brand of DRO that is suitable? The cross slide looks a little awkward to work with however.
    Secondly any suggestions for a brand LED machine light to use on the lathe as well, I may as well see better too.
    Nov 2015
    Brisbane Australia
    85
    I had fitted a DRO to one of my Hercus lathes sometime ago and I got different numbers when I turned the motor on with the cross slide. I think there may have been a bit of play in the system.
    From memory it was like .1mm, I was new to using a lathe and did not probe into it alot, I also thought maybe the machine was a little "light" for the DRO to be successfully used. Since then on my other lathe I use a DTI.
    I have since seen this method of attaching the DRO to the cross slide.
    I thought it looked good, it has a spring to keep tension in the system.
    Apr 2015
    Sydney, Australia
    23
    Smile Thanks for your view and picture.
    I had not considered "play" on the cross slide.
    Thanks for the picture.
    What is a DTI? I am not familiar with this descriptor.
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by Somedayplumbing View Post
    That looks good. Do you have a link to the website where you saw that?
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by Grahamross View Post
    Dial test indicator. Although I suspect he meant dial indicator (DI). A DI is what I use when I need accurate indication of cross slide movement.
    A permanent DRO on the cross slide would be nice though. For the work I do I don't think a DRO scale is as necessary on the carriage.
    Nov 2015
    Brisbane Australia
    85
    Yes sorry I meant Dial Indicator.
    And I got the photo off a Southbend facebook page.
    This is a dial indicator off a Southbend, I think it has probably got a magnet on the back to hold it in position
    6,480
    Hi Graham,
    Dial Test Indicator !
    In this picture the long thin device next to the drill chuck is a digital version of a dial indicator. In this instance being used to measure saddle movement.
    Nov 2007
    melbourne australia
    3,228
    Thanks. I have scoured the only two south bend lathe Facebook pages I could find and never found the pic of that DRO. It's a pity, as I'd like to know what brand of DRO he used and how he made the mount.
    Nov 2007
    melbourne australia
    3,228
    To clarify, this is a DTI:
    Nov 2015
    Brisbane Australia
    85
    Hi Chris, sorry I was wrong.
    I screenshot it off You Tube
    https://www.youtube.com/watch?v=oz9lSt_EX-A&t=5s
    Jun 2007
    sydney ( st marys )
    64
    4,890
    The bolt up option with supplied fittings is probably no.
    Any of the DRO's will work on your lathe.
    You will need to customise your fittings.
    Backlash in your screws should not be a concern to the DRO, you just need to make sure it's removed before use of the DRO ( by winding handles ).
    For most cross slide applications the scale is mounted at the rear of the cross slide
    ( an extension ). This can be an issue if a splash guard is fitted.
    Cost will probably be in the range of $300/$500 on the make.
    As mentioned earlier a dial indicator is/can be a very good cost effective alternative, if going this route I would suggest a minimum of 25 mm/ 1" of travel.
    Apr 2015
    Sydney, Australia
    23
    Default Thanks pipeclay, The DRO would be very good with multiple consecutive distances.
    Thanks Pipeclay,
    I will have a look about for a suitable brand DRO. The Dial Indicator is a good help.
    Apr 2015
    Sydney, Australia
    23
    Default Dti.
    Great picture of the DTI, I had never heard of the description, DTI but just only as a dial indicator.
    Apr 2015
    Sydney, Australia
    23
    Default Thanks BaronJ
    Yep I get it. I have not used the test word.
    Nice digital dial indicator.
    Hi Graham,
  15. #15
    Apr 2015
    Sydney, Australia
    23
    Default Proper looking setup
    Great setup. Thanks for the picture. Explains a lot.
  1. Help please... What brand of lathe is this?
    By woodnut damo in forum METALWORK GENERAL
    Last Post: 28th Aug 2019, 01:34 AM
  2. Late 1960's Stick Welder
    By DSEL74 in forum WELDING
    Last Post: 7th Oct 2014, 06:24 PM
  3. Replies: 2
    Last Post: 13th Sep 2012, 07:32 PM
  4. 3 jaw chuck brand for al-960b lathe
    By steran50 in forum METALWORK GENERAL
    Last Post: 15th Dec 2011, 10:08 PM
  5. Bolex Camera Factory 1960's
    Last Post: 22nd Nov 2011, 04:32 PM
