Results 16 to 29 of 29
27th Aug 2020, 02:39 PM #16Most Valued Member
That rear mounted DRO seems to have way more travel than necessary for a South Bend 9. My Hercus 260's cross slide has only about 150mm of travel. So I'm thinking a DRO scale with 150mm of travel should suffice. A spring mechanism like the one used on the DRO pictured would prevent damage to the scale in the event of an overrun.
Looking around the web it seems everyone sells 2 or 3 axis kits. Does anyone know where I can get a decent quality DRO kit with just one scale?Chris
27th Aug 2020, 05:38 PM #17Golden Member
- May 2020
- Willowbank QLD
- 517
Mate
Something like this is probably what you are looking for. It is the first one that come up on a google search so may not be the best place to buy.
https://www.timbecon.com.au/igaging-...ead-out-scales
I just googled igaging digital readout.
27th Aug 2020, 06:13 PM #18Most Valued Member
Thanks Steve. Well spotted, but I should have been more specific. I'd like something with a more traditional DRO control panel and LED display which could have a second axis added if I decide to do that later. I find the tiny buttons like the ones on that iGaging a real pain to use.
Also, given the amount of work required to mount the scale properly, I'd be looking at something with a higher spec than the iGaging. It's good to know it's available though.
CheersChris
27th Aug 2020, 06:27 PM #19Most Valued Member
Maybe these two items together?
https://www.machineryhouse.com.au/D5209
https://www.machineryhouse.com.au/D5200
It's a 170mm scale. Overall length is 282mm. I have 290mm between the back of my saddle and the splash guard. That's awfully tight. It might have to remain a pipe dream for me.Chris
27th Aug 2020, 06:30 PM #20Golden Member
- May 2020
- Willowbank QLD
- 517
I would give this place a try. You can buy the readout and scales seperate.
https://digitechdirect.com.au/shop/s...-lathes-mills/
https://digitechdirect.com.au/shop/s...e-170-470-5um/
30th Aug 2020, 08:12 PM #21Novice
- Apr 2015
- Sydney, Australia
- 23
30th Aug 2020, 08:57 PM #22Most Valued Member
Graham,
There's little to no info on fitting a DRO to a Hercus lathe, but there's plenty of threads on fitting a DRO to a South Bend 9 lathe. As far as I can tell, the Hercus and SB9 share identical castings for the bed and saddle. So any info you find should be applicable to the Hercus. I reckon the only practical way to mount the cross slide scale is at the rear. It's going to be in the way if mounted on either side of the saddle.
I've attached a pic I found of an iGaging scale fitted to a SB9.
Please keep us informed of your progress.Chris
31st Aug 2020, 03:45 PM #23Novice
- Apr 2015
- Sydney, Australia
- 23
Scale seems to fit nicely on the rear bed.
Hi jack620,
Appreciate the information and the picture. It looks like some effort will be required to follow through. I am using a DRO on a modern machine and am trying to learn how to use it more comprehensively (Instruction booklet referred to/snatching a look on the go).
I think it will be worth doing something on the Hercus.
Thanks,
PS Any comments on a LED type of Lathe light? Presently my lighting is average...on the lathe.
Cheers.
31st Aug 2020, 09:33 PM #24Most Valued Member
I have a wall mounted flexible arm LED light I bought at an IKEA store in Hong Kong. I've never seen it for sale here. It's mounted to the splash back and is long enough to reach over the top of the chuck when needed. Also good for shining into a bore.
Similar to this: https://www.aliexpress.com/item/3280...E&gclsrc=aw.dsChris
31st Aug 2020, 10:10 PM #25
Hi Chris, Guys,
I use one of the Ikea lights very similar to the one you linked to. My only objection to it is that it is permanently under power. The switch only breaks the feed to the LED. I make sure to remove the power when its no longer needed.Best Regards:
1st Sep 2020, 09:14 PM #26Most Valued Member
- Healesville
- 2,129
2nd Sep 2020, 02:08 PM #27Novice
- Apr 2015
- Sydney, Australia
- 23
2nd Sep 2020, 04:30 PM #28Most Valued Member
2nd Sep 2020, 04:37 PM #29Most Valued Member
Help please... What brand of lathe is this?
By woodnut damo in forum METALWORK GENERALReplies: 17Last Post: 28th Aug 2019, 01:34 AM -
Late 1960's Stick Welder
By DSEL74 in forum WELDINGReplies: 19Last Post: 7th Oct 2014, 06:24 PM -
TOS Lathe - SV-18R (Also known by the brand name MAS or ZBROJOVKA)
By Cueball in forum METALWORK GENERALReplies: 2Last Post: 13th Sep 2012, 07:32 PM -
3 jaw chuck brand for al-960b lathe
By steran50 in forum METALWORK GENERALReplies: 19Last Post: 15th Dec 2011, 10:08 PM -
Bolex Camera Factory 1960's
By Anorak Bob in forum METALWORK GENERALReplies: 11Last Post: 22nd Nov 2011, 04:32 PM
