Tony: There is a design for a precision saddle hand wheel that is calibrated in thou's. Simply using the existing saddle hand wheel won't give you accurate movement to the thou. Pop a dial gauge in the tailstock chuck and try it, it will be almost impossible to get to the thou repeatedly. The Myford S7LB leadscrew hand wheel is already calibrated in thou's and can easily be read to a 1/4 thou.
Interesting, thanks. Repeatability being the key issue. I'll give it a try with the dial gauge. There is plenty of backlash in mine, which won't help. I guess I was swayed by the calibrated saddle hand wheel on my modern lathe (which has a DRO, so I rarely read the saddle dial. Such decadence!).
Sent from my SM-N976B using Tapatalk
