Results 1 to 15 of 18
Thread: Coolant on the Hercus?
7th Jun 2020, 08:06 PM #1
I'm getting stuck into a bit of steel I picked up from my scrap pile and attempting to turn a twin Ball ended locking lever for one of my woodwork machines.
I'm getting some decent sized shavings, sometimes its blue with the heat, and the worst part of that is when bits land on Me .
The heat should be fine for the cutter shouldn't it ? I was playing with Tungsten and HSS .
Coolant means I can go harder I suppose and not worry about something starting to Glow?
Is the use of coolant a lot better for tool edge life ?
Do most use it or not ?
Is the mess not worth it ?
Some I have asked say they don't worry about it.
I did just order 5LT of cutting fluid from H&F with a $20 gravity bottle and line so will try it out.
The next step up is almost $300 with 20 lt container and pump . Is there a cheaper way to build your own with a suitable small pump ?
Rob
7th Jun 2020, 08:32 PM #2Most Valued Member
- 4,890
Coolant with HSS will generally give longer tool life, not necessarily heavier cutting.
Coolant with cemented or indexable carbide may provide some extended tool life, but coolant generally will reduce heat build up in the material your machining, it can also change the characteristics of the chips formed.
With coolant I prefer a constant flow, with your gravity system you will find that it may run out if cut is long , you will also need some way to recover the coolant ( hole in swarf tray and bucket ).
If looking for a cheaper alternative for a constant flow system you could try a plastic storage container ( 15 + litres ) a water feature pump some suitable hose and one of those magnetic eBay coolant pipe work or similar.
Others may talk of misting system, or just brushing cutting oil on.
Others will talk about the water based coolants possibly causing rust or staining of your machine, it's all up to you.
7th Jun 2020, 08:40 PM #3Member: Blue and white apron brigade
Lots of budget steps in between.
Pumps
From old Washing machine/dishwashers
Budget water feature pump.
Tanks
20L drums
6" PVC pipe with endcaps
Pipes
Poly Retic pipe, fittings and valves.
The best hose is silicone tubing, nice and supple doesn't go hard like clear .PVC
Alternatives
Misting system
Here's my Hercus system using a water feature pump
https://metalworkforums.com/f65/t135...t=coolant+tank
I can really recommend a recirculating flow that you tap into to get what you need. This aerates the fluid and reduces the amount of bug growth and stops it smelling bad.
I have a similar system on my MW BS but it now uses washing machine as the fine swarf clogs the magnetic internals of a water feature pump.
https://metalworkforums.com/f65/t184...t=coolant+tank
I have both flood coolant and misting on both my mill and late, Will probably retire the flood cooling on the mill - not ready to do the on the Lathe.
8th Jun 2020, 03:42 PM #4
Thanks for that Info Peter and Bob .
I have a water feature pump on the way and will see how I go doing a similar thing to Bobs set up .
Rob
9th Jun 2020, 04:41 PM #5Member
- Nov 2018
- Tasmania
- 97
I often use HSS applying just a dab of soluble cutting oil with a touchup paint brush as it makes less mess.
I would probably look at your speeds and feeds. HSS chips should not be getting past yellow ideally, it sounds as though your spindle is running too fast
A good rule of thumb for HSS on steel:
RPM = 9500/D
(D is workpiece diameter)
9th Jun 2020, 05:20 PM #6Most Valued Member
9th Jun 2020, 08:53 PM #7
When I bought my lathe it had a pump and nozzel for coolant which I decided I wouldn't use as I wasn't using this lathe for production so I've resorted to using dabs of oil.
9th Jun 2020, 10:18 PM #8Gear expert in training
- 34
- 1,080
Aside from prolonging tool life and reducing heat, using lubricant of any kind will also improve the surface finish.
If the gravity fed system will be giving you regular drops, rather than a constant stream, don't use it with carbide; the thermal stress from repeatedly being heated and cooled is worse for it than just running dry.
11th Jun 2020, 02:03 AM #9Intermediate Member
- May 2020
- ACT
- 27
Mist all the way
FWIW - I've had various lathes over the past 20 years and have never needed flood coolant. That is to say that while one lathe I owned had it from factory, it actually didn't need it. Mist is very easy, minimal cost, minimal mess, and almost as effective as flood at cooling and lubrication; unless you're turning like a boss and constantly driving the machine to it's max. Even then I'd debate the necessity!
One of the neat things about mist (if you're on a tight budget) is you only need invest in one unit, that can be magnetically attached to your lathe, mill, bandsaw etc. Just move it to where you're working. Oh, and you will need a good source of compressed air.
Flood coolant introduces a whole lot of moisture into the machine that it's running in, and combine that with swarf and you end up with a horrible soup of swarf, dust, water, oil and rust. Even if changing the coolant once a month it will still happen! Wild horses won't drag me back there!
11th Jun 2020, 09:45 AM #10Member: Blue and white apron brigade
I agree the misting is superior but disagree about flood coolant being as big a problem as you make out. My experience at work and at home is that most of the issues you listed are a result of users being too stingy with the soluble oil. They either buy cheap oil and and/or don't use enough of it in the water, or only top up the sump with water. I only cleaned my sump and replace the coolant about once a year and about once a month I'd top up the sump with a few hundred mL of freshly made coolant.
One reason users change the coolant more regularly that this is because of bugs growing in the coolant make a bad smell. This is much reduced if a vigorous recycling action is incorporated into the pumping system so that the pump moves the coolant around in an auxiliary loop which adds oxygen into the coolant which kills the bugs.
The main reason I've moved to a mister is that I don't like the way the flood coolant is thrown all over the place
12th Jun 2020, 10:37 PM #11
How do you apply a mist to the work ? Ive never heard of it . How is it Pumped and pointed at the job?
I was pushing for as much removal as possible with this . I had a bit to get through. It started at around 35mm . My first serious steel job on my lathe .
The motor my lathe came with is a bit annoying. The mount isn't right so it jiggles around under a load pivoting on two points and its .75 HP.
A bit stronger and less belt slip would be nice . How strong can you go with motors on these lathes before it ends in tears?
Rob
12th Jun 2020, 10:56 PM #12Most Valued Member
- 4,890
1 hp is okay, you would probably start crying around 5 hp and definitely at 10, if it James your finger.
12th Jun 2020, 10:57 PM #13Member
- Nov 2018
- Tasmania
- 97
I've got 1 HP on mine, but I'm limited by belt slip. I've taken 60 thou (1.5 mm) depth of cut in steel, but the spindle starts slowing, so I find 40 thou as a good depth
To fix the belt slip I'll replace the belt, and after some reading I'm tempted to go for a cogged V belt as they grip better it sounds
13th Jun 2020, 12:01 AM #14
back gear
if you have a low powered lathe, you can engage the back gear and take a deep depth of cut , use power feed . I've done up to 6mm deep cuts in mild steel , its rather a fascinating thing watching the process. The tool needs to have the appropriate angles and be sharp.
13th Jun 2020, 12:18 AM #15Intermediate Member
- May 2020
- ACT
- 27
"How do you apply a mist to the work ? Ive never heard of it . How is it Pumped and pointed at the job?"
Try the Noga MC1700 mini-cool kit, or a similar unit from ebay. It has a mag base on it so you place it on the carriage, adjust the flexible nozzle to where the action is and supply compressed air and a small container of cool mist fluid nearby. It draws the fluid up from the bottle via the venturi effect and uses compressed air for a lot of the cooling. Compared to flood coolant it's a breeze to setup, no coolant to be constantly changing, oh and very little mess.
Coolant - yet again
By bollie7 in forum METALWORK GENERALReplies: 19Last Post: 8th Jan 2020, 10:33 AM -
What Coolant
By Auskart in forum METALWORK GENERALReplies: 6Last Post: 29th Mar 2019, 09:01 PM -
H&F coolant
By morrisman in forum METALWORK GENERALReplies: 8Last Post: 2nd Nov 2013, 01:01 AM -
Coolant
By CGroves in forum METALWORK GENERALReplies: 3Last Post: 23rd May 2012, 08:35 PM -
Using Coolant
By simonl in forum METALWORK GENERALReplies: 13Last Post: 22nd Dec 2011, 10:11 PM
