Results 46 to 55 of 55
Thread: Chuck key
18th Jun 2020, 11:02 AM #46
Hi guys,
I just want to acknowledge Racingtadpole, who offered to make me a chuck key. Im only new to metalwork after many years at woodworking. His generosity is just terrific and much appreciated. So i just wanted to publicly thank him as i appreciate his kind gesture
18th Jun 2020, 05:18 PM #47Intermediate Member
- May 2020
- ACT
- 27
Racingtadpole I'm just quoting industry standard. It's true that a soft chuck key in a home shop is likely to last longer than in a commercial application. The upside is that a soft key can be easily straitened if bent, whereas with a conventionally made key that is not so easy.
Regardless, I think you're a generous man to make a new key for Sailor! The world needs more people like you.
18th Jun 2020, 09:08 PM #48Senior Member
- Jul 2011
- Berowra Waters
- 149
Mine
I modified mine too, it works quite well. Should have shortened the ball end though, I’ll do it one day.
19th Jun 2020, 01:40 AM #49
19th Jun 2020, 09:58 AM #50Most Valued Member
19th Jun 2020, 08:49 PM #51Intermediate Member
- May 2020
- ACT
- 27
I really don't want to come across as a smart alec, but I do struggle with misinformation.
If you do a bit of a survey online you will see that most suppliers mention that lathe chuck heys are 'hardened, or 'induction hardened'. Some of them also mention the material the key is made of (generally a bit vague like 'alloy steel') which points to 3/4 type. Just one example below, but there's dozens of them out there if you want to amuse yourself.
I have three lathe chuck keys here that I have run a file over, all three are quite resistant to a new sharp quality file. If you google the topic there's a wealth of information out there on what a lath chuck key should be made of, and how it should be hardened (through not case) etc.
19th Jun 2020, 10:24 PM #52Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
Misinformation is what keeps forums on the internet alive.. this place is riddled with it on a regular basis..
20th Jun 2020, 01:34 AM #53Intermediate Member
- May 2020
- ACT
- 27
20th Jun 2020, 05:57 PM #54Most Valued Member
I ran a file over my chuck keys today. Both are soft. Very soft in fact. Unknown provenance; but I think I can guess.
20th Jun 2020, 09:05 PM #55
Hi Chris,
I've just checked the chuck key that came with the 125 mm HBM, that one is as hard as hell, the file just skates over the surface. All my other ones are soft enough to file easily including my drill chuck keys. Though I've only checked the drill chuck ones that I use regularly.Best Regards:
Wax Chuck !
By BaronJ in forum METALWORK GENERALReplies: 10Last Post: 16th Sep 2018, 01:17 PM -
3MT Chuck over at WWF
By Acco in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 22nd Jan 2018, 12:59 PM -
300 mm 4 jaw chuck $50.00
By KBs PensNmore in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 20th May 2016, 03:29 PM -
collets : to chuck or not to chuck
By steamingbill in forum METALWORK GENERALReplies: 4Last Post: 26th Jul 2014, 10:17 PM -
New 3 jaw chuck
By Tiger in forum METALWORK GENERALReplies: 5Last Post: 24th Sep 2008, 10:17 PM
