Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 55
Thread: Chuck key
  1. #16
    May 2020
    ACT
    27
    If you want the original item they are available from Pratt Burnerd. I'm waiting for a price bit not expecting it to be cheap. I Imagine once I get a price and pick myself up off the floor I'll end up spinning one up out of some 20mm 4140 stock. Providing you have a mill it's not a major job to make one.
  2. #17
    6,444
    Pratt Burnard the chuck people are now part of the "600" group of companies !
    I've just bought a replacement 100 mm three jaw chuck from ARC Euro here in the UK, the chuck key that comes with it is identical in size to the original PB one.
    For the price I'm quite pleased with the quality of the chuck, the run out at the chuck jaws is less than 2/10 ths thou using a 20 mm diameter test bar and barely alters 150 mm away.
    Unfortunately I can't say the same for the pre machined Myford fitting backplate that I bought from them some time ago. I originally bought it to put a ER32 collet chuck on it. The metal was coarse and rough to machine I couldn't get a smooth finish no mater how much I tried. I ended up grinding the surface to get a good finish. Also when drilling the three holes for the M8 cap screws it was like drilling stainless steel. Horrible stuff !
  3. #18
    Sep 2008
    Riddells Creek, Vic.
    831
    Hi BJ, are you saying that the Arc Euro chuck has a runout of .008"(0.2mm)? If so, it sounds a bit much, even for a 3 jaw.
  4. #19
    Mar 2011
    Southern Flinders Ranges
    1,536
    This is where things got to at the end of play today.. That and the discovery I can’t currently replicate the original flattened end of a Burnerd key on a piece of 10mm round bar because the hydraulics on my press are marking their territory too badly..
  5. #20
    Apr 2003
    melbourne
    69
    19
    Looking good to me!
  6. #21
    6,444
    Hi Techo
    Quote Originally Posted by Techo1 View Post
    Thanks for your post, I missed a "0" off the end. I've been back and corrected it. It gets confusing swapping between imperial and metric gauges !
    I've re-edited it because I still got it wrong ! It should read two tenths of a thou ! I'm going to stop trying to come to terms with mm.
  7. #22
    6,444
    Thumbs up Getting it wrong !
    I thought that since I had made a right pigs ear of measuring and reporting run out figures for my new ARC Euro chuck I would re-do the measurements and take some pictures as I went along.
    I used a metric dial indicator this time so I couldn't get confused with thous.
    This indicator is a 0.01 millimetre one. I started with an 8 mm diameter bar and rotated the chuck until the reading was the lowest nearest to the indicator. I then zeroed the indicator. I then rotated the chuck until the reading was a maximum.
    In this case four divisions. (1.6 thou)
    Then I did the same with the 20 mm diameter test bar.
    It only moved three divisions this time. (1.2 thou)
    Then I repeated the exercise with a 40 mm diameter bar.
    Only two divisions this time. (0.8 thou)
    I would have liked to try a bigger diameter say 50 mm but I don't have anything that big. It seems that the run out improves as the work diameter gets bigger.
    So apologies for making a screw up in my original post. Thanks also to Lex for the prod to get it right
  8. #23
    Nov 2007
    melbourne australia
    3,228
    Hi John,
    I think I see where the confusion creeps in. You're using a metric DI but reporting the results in thou. Why not just report the measurement in mm straight off the DI? You're adding a conversion that introduces the potential for error.
  9. #24
    6,444
    Hi Chris, Guys,
    Chris, I've used thous all my life but most on the forums seem to want measurements in millimetres. But yes you are right, trying to convert readings is causing confusion.
    A few months ago I bought a HBM 125 mm three jaw chuck and back plate. I machined the register on the backplate for a nice snug fit into the back of the chuck. At this point I couldn't measure the jaws. Anyway after drilling for the M8 mounting holes and threading the back plate I mounted the chuck. On checking the chuck body there was about 10 thou eccentricity.
    After having gone through measuring the new ARC Euro 100 mm chuck, I decided to do the same with the HBM one. Using the same setup as before, I had nearly 2 mm of runout with an 8 mm rod. This got worse as I moved to my 20 mm test bar.
    I ended up machining a further 15 thou of the register and drilling out the M8 threads to 9 mm holes and use M8 cap screws from the back. This allowed me to tap the chuck central with a plastic faced hammer. I managed to get the run out down to 3/10ths mm with an 8 mm rod in the jaws. Even so the run out gets worse with increasing diameters. With a 45 mm diameter bar the run out is just short of a whole millimetre.
    I believe that HBM is an Indian manufacturer. I certainly won't be buying another one.
  10. #25
    Nov 2007
    melbourne australia
    3,228
    That's terrible.
    My experience with Indian tools hasn't been good either. Hopefully they will get their act together quickly and be a viable alternative to China.
  11. #26
    Mar 2011
    1,536
    Ready for the post office tomorrow..
  12. #27
    Apr 2003
    melbourne
    69
    19
    Fantastic!
    I’m so appreciative. Can’t wait to use it now. Blackened as well!
  13. #28
    Mar 2011
    1,536
    For the life of me I now have no idea where the key for my Pratt 3 jaw is
    Cant be too far away, I used it to make yours
  14. #29
    Apr 2003
    melbourne
    69
    19
    It’s there looking right at you! When you find it, you’ll say to yourself “ now I remember putting it there”.
    I do that about twice a day.
  15. #30
    Jul 2011
    Berowra Waters
    149
    Default A file?
    Maybe just buy a 10 mm and file 0.5 off each face? Wouldn’t take very long I would think.
  1. Wax Chuck !
    By BaronJ in forum METALWORK GENERAL
    Last Post: 16th Sep 2018, 01:17 PM
  2. 3MT Chuck over at WWF
    By Acco in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 22nd Jan 2018, 12:59 PM
  3. 300 mm 4 jaw chuck $50.00
    By KBs PensNmore in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 20th May 2016, 03:29 PM
  4. collets : to chuck or not to chuck
    Last Post: 26th Jul 2014, 10:17 PM
  5. New 3 jaw chuck
    By Tiger in forum METALWORK GENERAL
    Last Post: 24th Sep 2008, 10:17 PM
