Page 4 of 4 FirstFirst 1234
Results 46 to 55 of 55
Thread: Chuck key
  1. #46
    Apr 2003
    melbourne
    69
    19
    Hi guys,
    I just want to acknowledge Racingtadpole, who offered to make me a chuck key. Im only new to metalwork after many years at woodworking. His generosity is just terrific and much appreciated. So i just wanted to publicly thank him as i appreciate his kind gesture
  2. #47
    May 2020
    ACT
    27
    Your thoughts may differ but I see no reason to use anything exotic to make a chuck key from. I made sailors from a piece of mystery metal. Some applications need material like 4140, I don’t see a chuck key being one of those applications. The picture of the one made from square bar chewed by an angry beaver earlier in the thread tends to support this theory
    Racingtadpole I'm just quoting industry standard. It's true that a soft chuck key in a home shop is likely to last longer than in a commercial application. The upside is that a soft key can be easily straitened if bent, whereas with a conventionally made key that is not so easy.
    Regardless, I think you're a generous man to make a new key for Sailor! The world needs more people like you.
  3. #48
    Jul 2011
    Berowra Waters
    149
    Default Mine
    I modified mine too, it works quite well. Should have shortened the ball end though, I’ll do it one day.
  4. #49
    6,480
    Hi Chris, Guys,
    Are chuck keys hardened?
    Not as far as I'm aware, certainly non of mine are ! Now the drill chuck keys, I don't know. I would have to rub a file over them.
  5. #50
    Nov 2007
    melbourne australia
    3,228
    Not as far as I'm aware...
    Me either John.
  6. #51
    May 2020
    ACT
    27
    I really don't want to come across as a smart alec, but I do struggle with misinformation.
    If you do a bit of a survey online you will see that most suppliers mention that lathe chuck heys are 'hardened, or 'induction hardened'. Some of them also mention the material the key is made of (generally a bit vague like 'alloy steel') which points to 3/4 type. Just one example below, but there's dozens of them out there if you want to amuse yourself.
    I have three lathe chuck keys here that I have run a file over, all three are quite resistant to a new sharp quality file. If you google the topic there's a wealth of information out there on what a lath chuck key should be made of, and how it should be hardened (through not case) etc.
  7. #52
    Mar 2011
    Southern Flinders Ranges
    1,555
    Misinformation is what keeps forums on the internet alive.. this place is riddled with it on a regular basis..
  8. #53
    May 2020
    ACT
    27
    True that!
  9. #54
    Nov 2007
    melbourne australia
    3,228
    I ran a file over my chuck keys today. Both are soft. Very soft in fact. Unknown provenance; but I think I can guess.
  10. #55
    6,480
    Hi Chris,
    I've just checked the chuck key that came with the 125 mm HBM, that one is as hard as hell, the file just skates over the surface. All my other ones are soft enough to file easily including my drill chuck keys. Though I've only checked the drill chuck ones that I use regularly.
  1. Wax Chuck !
    By BaronJ in forum METALWORK GENERAL
    Last Post: 16th Sep 2018, 01:17 PM
  2. 3MT Chuck over at WWF
    By Acco in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 22nd Jan 2018, 12:59 PM
  3. 300 mm 4 jaw chuck $50.00
    By KBs PensNmore in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 20th May 2016, 03:29 PM
  4. collets : to chuck or not to chuck
    Last Post: 26th Jul 2014, 10:17 PM
  5. New 3 jaw chuck
    By Tiger in forum METALWORK GENERAL
    Last Post: 24th Sep 2008, 10:17 PM
