Results 1 to 14 of 14
    Aug 2016
    Adelaide
    80
    Default hercus cross slide binding
    I've had some trouble adjusting the cross slide on my hercus. If I adjust it so there's minimal play in the normal operating range I can't slide it right off the back because it binds at the back. I think the machine has seen a decent amount of use so not unexpected. I assume either the saddle or slide dovetails are out of parallel. To correct this problem, would I have to grind or scrape the dovetail surfaces? Has anyone tried to fix this issue? I'd actually like to learn how to scrape but I would have to invest quite a bit to get the required tools.
    Jul 2016
    35
    1,522
    You can scrape them on a pretty low budget, to get it good enough you can just braze a chunk of carbide onto a springy handle and get cracking. you need some kind of flat to check the surface then some dowel pins and a mic to get the back side parallel to the front. but dont go for the whole length just knock the highspots off each end to get the travel back.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    What type of play are you trying to eliminate?
    Why if you have adjusted it through its normal operating range do you then want to remove the nut from the leadscrew and slide it off?
    Aug 2016
    Adelaide
    80
    Not sure what to call it but play when I grab each end of the cross slide and rotate in the plane of the bed. If I adjust it so it travels the whole length then I can rotate is slightly when slides is positioned closer to the operator. It would be nice to slide off to clean without adjusting gibbs, or not have it tighten up as the slide moves to the other end.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    How easy is the cross slide to wind through its normal range of travel, can it be moved using thumb and index finger?
    Where have you got the cross slide positioned whilst adjusting the gib?
    It seems unusual to have excessive wear in the dovetail as it just runs back and forth on the dovetail of the saddle, any real wear in these can be adjusted by the gib.
    Aug 2016
    Adelaide
    80
    How easy is the compound to wind through its normal range of travel, can it be moved using thumb and index finger?
    Where have you got the compound positioned whilst adjusting the gib?
    The binding is in the cross-slide. To adjust gibbs in the cross-slide I remove the compound. I need to get some gauge pins or dowel pins so I can make some measurement on the saddle.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Sorry corrected the wording in my answer.
    There is no need to remove the compound from the cross slide to adjust the gib unless that what you want to do.
    Before you go to the trouble of getting gauge pins or the like for measuring what ever you plan to measure, get hold of some bearing blue or similar and check the fit against the none gib dovetail, if it blues along its face and the cross slide gib I would say it's okay.
    Can you wind the cross slide with two fingers after you adjust the gib, and where is the cross slide in relation to the saddle when you adjust the gib?
    Aug 2016
    Adelaide
    80
    I adjusted the gib with the cross-slide end lined up with the front saddle end, approximately (no over hang) then I moved it back to see how snug it was. With the initial setting I couldn't slide the cross-slide off the back at all. I then loosened the back gib screws a bit to get a bit more travel without introducing too much sideways play. At that setting it seemed ok, but then I had to angle the compound for a cut which required the cross-slide to go towards the back more and it seemed a bit tight back there. This got me thinking about whether I should try fix it.
    I can wind the cross-slide with two fingers for most of the travel region of interest.
    Can suggest a bearing blue product to try?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Prussian Blue, bearing suppliers/ spare car parts suppliers engineers suppliers.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Have you attempted to adjust the gib with the cross slide leadscrew engaged in the cross slide nut?
    Aug 2016
    Adelaide
    80
    No, only because I could get a better feel for the fit by sliding by hand. Any reason to do it with the screw & nut?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Yes, any misalignment or wear may cause the cross slide to bind, but if doing it your way works doesn't matter.
    If you set the gib without the nut in the cross slide how do you then put the nut in and engage it with the screw.
    Generally setting the gib with screw and nut attached would take about 5/8 mins, doing the lock nuts may take longer.
    Aug 2016
    Adelaide
    80
    I have to ensure that I can slide the cross slide back just enough to put the nut back in. Which is part of the initial problem. I get your point about leaving the nut in. Seems to take me ages to adjust the screws & locking nuts. Find it hard to tighten the nuts without changing the screws.
    Mar 2011
    Southern Flinders Ranges
    1,555
    Quote Originally Posted by monchochos View Post
    One of my part complete projects is making longer lock nuts to use over longer grub screws to clear the compound to solve exactly that problem.
  1. Hercus 9C cross slide milling rig.
    By Tex260Z in forum THE HERCUS AREA
    Last Post: 17th Mar 2020, 01:15 PM
  2. hercus c extended cross slide
    By azzrock in forum THE HERCUS AREA
    Last Post: 15th Feb 2020, 09:38 PM
  3. Cross Slide Scraping Hercus 260
    By Abratool in forum THE HERCUS AREA
    Last Post: 14th Nov 2014, 05:06 PM
  4. Backlash in Hercus 260 cross-slide
    By jack620 in forum THE HERCUS AREA
    Last Post: 4th Mar 2013, 06:19 PM
  5. Hercus 260 Cross-slide play
    Last Post: 26th Sep 2011, 08:47 PM
