Results 1 to 5 of 5
Thread: Hercus Mill Upgrade
3rd May 2020, 09:19 PM #1Senior Member
- Feb 2009
- jilliby nsw
- 111
Hercus Mill Upgrade
Well finally bit the bullet to make my hercus mill a bit more usable. With minimal workspace in the Z axis stopping a few jobs from advancing towards completion I did my research on what others had done to combat this problem As usual the "Hercus Area" was quite useful as well as a few youtube machinist chanels. Seemed there was 3 areas that needed alteration ie base block, extended z axis screw and extended z axis dovetail slide.
The base block was made from welding together 4 sections of 150mm C section. Next to ensure the top & bottom were parallel I use the shaper to clean up the top & bottom faces. Required a millimeter or two of steel to be removed to clean the faces up. Hot rolled steel although looking to be flat & square is far from it. After shaping I adapted my T&C grinder to become a surface grinder and trued up the shaped faces
mill base grinding.jpgmill base shaper1.jpgmill extended dovetail.jpgmill dovetail shaped.jpgmill upgraded.jpg
Next step was extending the table screw. After measuring up the existing screw it appeared to be a non standard thread @ 18.7mm OD x 14 TPI & LHand. Cut a 10" piece of 3/4 bar, machined down the blank, made a HSS tool for a LH Acme thread and proceeded to cut the thread. With minimal fiddling it fitted the existing acme nut beautifully. Next bit was the tricky bit. I cleaned up the end of existing screw and bored a 1/4 hole in the the bottom of it. The new section was turned down one end to form a 1/4' pin and the 2 sections were pressed together. Minor tweeking was needed to get the mating threads in line to allow the nut to moved effortlessly between the new and old thread.
Last piece was to extend the slide. Found some Cast Iron and shaped it flat both sides Calculated dovetail angle using an improvised bevel. It was some weird angle like 51 degrees. Anyway thanks to Mr Shaper I managed to cut them and once again used my makeshift T&C surface grinder to clean up the dovetail faces. This was attached to the base block with 3 cap head screws and shimmed to suit the rough block surface.The front of the dovetail extension face has since been flycut and the base block painted to match the mill. Mill still machines nice and square as it did before the upgrade. All in all not too difficult a job to do with the big added benefit of having a more usable workspace. Unfortunately I get a bit engrossed in my work and forget to take pictures.
5th May 2020, 05:25 PM #2Member
- Nov 2018
- Tasmania
- 97
Great work!
I'm halfway through a riser block for my Hercus mill
I'm also fabbing a box and have a chuck of cast iron ready
How did you keep dovetail alignment?
5th May 2020, 08:53 PM #3Senior Member
- Feb 2009
- jilliby nsw
- 111
made it slightly thinner in thickness than the existing. Lined up face & dovetails and made packing to fit behind the 3 capscrews to hold it in place. The casting below my existing dovetail was all over the place. If I had another mill I would have machined the mill casting to save a lot of trial and error to get it positioned correctly.
6th May 2020, 05:04 PM #4Member
- Nov 2018
- Tasmania
- 97
I'm thinking of doweling mine so I can take it off, machine it, trial fit, machine it etc and maybe scrape the final amount. It's going to be finnicky
How long is your extension? I'm aiming for 120 mm which from my measurements means I can keep the same leadscrew. I have a Mk2 mill though which I think is slightly different in terms of travel
6th May 2020, 10:08 PM #5Senior Member
- Feb 2009
- jilliby nsw
- 111
extension dovetail is around 200 mm long but only use about 160mm.. My leadscrew was a neat fit so needed extending to be able to use the full benefit of the base block. There is enough room in the base cabinet to accommodate the extended leadscrew even if the base block is removed
Hercus o mill Vertical mill head lubrication
By china eyes in forum THE HERCUS AREAReplies: 0Last Post: 14th Oct 2018, 06:57 AM -
X2 Mill Mods/Upgrade
By mahgnia in forum METALWORK GENERALReplies: 16Last Post: 28th Nov 2015, 09:56 PM -
Hercus 260 CTM upgrade
By boilermaker8 in forum THE HERCUS AREAReplies: 2Last Post: 17th Nov 2011, 05:46 PM -
Arboga EM825 mill vs Hercus model 0 mill?
By neksmerj in forum METALWORK GENERALReplies: 23Last Post: 14th May 2011, 03:16 PM -
Hercus upgrade
By .RC. in forum METALWORK GENERALReplies: 13Last Post: 16th Oct 2010, 11:37 AM
