Results 1 to 6 of 6
Thread: Hercus 9” serial number location
1st May 2020, 02:29 PM #1
Hi guys,
I’m looking to purchase a lathe, and the current owner has sent me some photos. It’s covered in bird poop.
It’s definately a type A as it has a gearbox. I’m not sure where the serial numbers are located on the bed ( assuming they are on the bed ) do they normally have a matching taistock?
The current owner doesn’t know where to look, but I’m sure someone will know. All he knows is he bought it from the old Swinburne tech. It’s a fair drive for me so any info prior to looking all the better
Thankyou for any help.
1st May 2020, 03:02 PM #2
There should be a serial number on the data plate on the front of the gearbox, one on the bed (tailstock end, on the rear way, between the flat and the V way), one on the tailstock (there should flat machined on the casting of the base, under the hand wheel), and one on the H frame holding the counter/jack shaft pulley. Hard to describe in words...I seem to recall someone publishing some photos on this forum to help. You could also look up the Australian Metalworking Hobbyist web site, there is info on identifying your lathe there.
Good luck, Tony
Sent from my SM-N976B using Tapatalk
1st May 2020, 03:18 PM #3
3rd May 2020, 10:17 AM #4Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,185
From the Hercus Spare Parts Manual:
3rd May 2020, 10:21 AM #5
3rd May 2020, 02:43 PM #6
Thanks guys, most helpful. Just got to find one for sale now!
Hercus Surface Grinder. Serial Number location?
By A J in WA in forum THE HERCUS AREAReplies: 6Last Post: 30th Sep 2015, 02:50 PM -
sheraton serial number AR111M
By danielhobby in forum THE HERCUS AREAReplies: 6Last Post: 11th Oct 2012, 08:33 AM -
Hercus Model O Mill Serial Number.
By triton2 in forum THE HERCUS AREAReplies: 2Last Post: 22nd Mar 2010, 03:48 PM -
Hercus Serial Number
By Mark2 in forum THE HERCUS AREAReplies: 7Last Post: 22nd Apr 2009, 08:32 PM -
Hercus 9" Serial Number BS316
By bitza500 in forum THE HERCUS AREAReplies: 12Last Post: 25th Jul 2008, 01:38 AM
