Results 1 to 2 of 2
    Jul 2008
    near Warragul, Victoria
    3,725
    Default Thread dial project
    For a SB I think. I made one for my Sheraton but I made a mistake with the gear . It should be a normal flat faced gear to mesh with the slotted leadscrew, I put a concave face ( as seen in this project ) on the gear and it doesn't mesh correctly , it pushes itself off the leadscrew
    Sep 2007
    Wentworth Falls NSW 2782
    77
    134
    When I made mine I didn't have a working milling machine so I made a jig using an existing 32T gear as a master and made it on the shaper. I made a form tool and set the jig at the helix angle of the leadscrew. The material was cast iron from a window weight. Using this method meant no curvature of the gear but it works fine. The lower apron part was made from a pipe reducer.
    F
  1. How to re-calibrate my Thread Dial Indicator
    By oohsam in forum METALWORK GENERAL
    Last Post: 16th Jun 2014, 08:13 PM
  2. Thread Chasing Dial
    Last Post: 14th Dec 2009, 03:00 PM
  3. Fitting thread chasing dial.
    By mob in forum THE HERCUS AREA
    Last Post: 15th Nov 2009, 12:16 AM
  4. Does anybody have plans for a thread dial
    By bitza500 in forum THE HERCUS AREA
    Last Post: 16th Jun 2009, 03:51 AM
  5. Hercus thread dial gauge?
    Last Post: 4th Jun 2008, 04:56 PM
