Results 1 to 11 of 11
    Mar 2012
    South Australia
    33
    Default VFD on a Hercus 260
    Have just acquired a 260 with 3ph motor. Fitted with ASEA 0.37kW 415V connected as Y. Will this take VFD?
    Mar 2011
    Southern Flinders Ranges
    1,536
    The technically correct answer is yes, but only if you have 415 supply
    The answer you are probably more looking for is no or maybe if you want to run a single to 3phase unit. It is maybe if you have access to the far end of the windings in the terminal box to convert it to Delta, if you don’t the answer is no.
    A single phase motor, whilst not as convenient, is cheaper than a VFD conversion hands down every time, unless you get either the motor or the VFD or both very cheaply.
    Apr 2020
    Hackham West
    55
    55
    Are you asking because you have single phase only in your shed?
    7,183
    If the motor is like the ASEA motor on my Hernia mill they are easily convertible to ∆ in the motor terminal box.
    https://metalworkforums.com/f189/t20...ll#post1935297
    You will need to know what you are doing.
    A suitable VFD can be had for under a $100.
    If it was me and it was possible I would replace the motor with something that is about double the power.
    This will give you a wider VFD speed range with full power.
    Maybe have a read of the document on this page https://www.woodworkforums.com/f271/vfds-newbies-232742
    Mar 2012
    South Australia
    33
    Quote Originally Posted by ericks2 View Post
    Yes that is the case. I have several ABB drives rated at 1.1kW
    Apr 2020
    Hackham West
    55
    55
    Okay...if you post a pic of the inside of your terminal box then i can advise you whether you will be able to change to delta like bob said. If it's possible then i'll tell you how to do it
    Mar 2011
    1,536
    No, it gives you a larger motor running at reduced power, extra heat and insufficient cooling when running at the ridiculously low frequencies often touted as being usable on here.
    7,183
    Humm . . . . .I've had a 1HP motor running on my Hercus from as low as 15Hz up to 120 Hz for 9 years, sometimes for hours at 25Hz - not even a hint of a problem. Not many of us operate at production shop levels of output.
    I would not normally advise going below about 15Hz but here's an example where I found I can. On my small WW lathe I heat form 6" PVC "bell mouth hoods" with a hot air gun for dust extraction systems. Just like my MW lathe I have the same VFD and a 1HP donk but running as low as about 10Hz. The forming process takes about 5 minutes at light load and then about 3 minutes at higher load. The motor does indeed get slightly warm under high load but then when cooling down the fully formed hood the motor speed is increased to 25Hz and the dust extraction system is turned on for about 5 minutes - this pulls ~1200 CFM of shed air across the lathe and from around the motor and quickly cools the motor back to RT again.
    I have made many hundreds of these hoods for mens shed - the most likely thing I will have to replace in the near future is the live centre bearing.
    Mar 2012
    South Australia
    33
    I will post a photo after i collect the lathe next weekend.
    Thanks everyone for your assistance.
    Mar 2011
    1,536
    Bob, you missed the point.
    The advice you offered was factually incorrect.
    Apr 2020
    Hackham West
    55
    55
    Quote Originally Posted by alfclp View Post
    No worries...
  1. Hercus #3A or #1 T&C smaller wheel guard and Hercus #3A wheel shaft pulley.
    By lamestllama in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 30th Aug 2019, 12:01 PM
  2. Hercus 9" vs hercus 260 ????????
    By bitza500 in forum THE HERCUS AREA
    Last Post: 26th Jun 2009, 10:50 PM
  3. Hercus parts on Ebay from Hercus
    By bollie7 in forum THE HERCUS AREA
    Last Post: 8th Oct 2008, 02:59 PM
