Results 1 to 4 of 4
    Apr 2020
    Leichhardt NSW
    42
    Default Hercus 9C H-drive v-belt change?
    Another newbie question: How do I change the secondary drive v-belt on an H-pattern Hercus 9? Do I need to use a non-continuous A35-equivalent? Seems like both upper and lower shaft have no way, aprart from complete teardown to slip a v-belt on. Or am I missing something obvious?
    As a BTW, the new motor has arrived and I installed it this morning. The machine lives! Hooray! Not to provide a proper start/stop box and I'll be happy. Maybe even install a tacho...
    Jun 2007
    sydney ( st marys )
    64
    4,890
    You will need to either pull the Headstock spindle and counter shaft spindle (not a bad thing, can check bearing surfaces ) or fit a suitable A size link belt.
    Apr 2020
    Leichhardt NSW
    42
    Thanks. Pretty much what I thought.
    Out of curiosity, how much effort is required to pull the two spindles?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Not much effort for the counter shaft as long as it's in good nick, just check for burs or bruises on the ends of the shaft and where the grub screws seat.
    The Head Stock spindle can also be a pretty easy removal procedure as long as the Bull Gear is not overly tight on the spindle.
    Remove the take up nut and fibre washer, loosen the bearing housing bolts, give the gear train end a hit with a bit of hardwood and hammer, it should start to move, the Bull gear will be on a key, in the bottom of the bearing housings will be felt and a spring, if you are concerned that you may damage them, bring a point onto a couple of bits of welding rod or similar, remove the side oil points, you should then be able to pull the felt and spring down with the pointed end of the rod, you really only have to worry once the bearing journals on the spindle have cleared the bearing housing, replacement is just the reversal after things are cleaned.
    Mark the spindle where the keyway is so you can line it up with the Bull Gear.
    Dont lose the key.
  1. CC Engineering TCG belt drive
    By bob ward in forum METALWORK GENERAL
    Last Post: 2nd Jun 2018, 03:32 AM
  2. Hercus 9" AR Belt change
    By MikeMaidavale in forum THE HERCUS AREA
    Last Post: 13th Mar 2015, 06:38 AM
  3. X2 Mill Belt Drive
    By mahgnia in forum METALWORK GENERAL
    Last Post: 21st Mar 2013, 05:34 PM
  4. Hercus Tool and Cutter Grinder - Spindle Drive Belt and Pulleys
    Last Post: 6th May 2012, 03:32 PM
  5. How to belt drive just about anything from any engine - DIY
    By yachtwork in forum METALWORK GENERAL
    Last Post: 23rd Jan 2010, 03:06 PM
