Results 1 to 4 of 4
20th Apr 2020, 03:48 PM #1Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 275
Craftsman motor. Does it overheat?
I am setting up a long bed Craftsman (with a three phase motor) that has been in storage for several years, and I have never used. I have been considering putting a fan - or two on the back of the cabinet before I put the lathe back on top. Much easier to lay the cabinet on its side and cut the holes now. I have been considering this as my 8" Boxford shaper motor gets hot in its cabinet. It too is an "under drive" set-up. Am I wasting my time? The advice of Craftsman owners is requested.
20th Apr 2020, 07:25 PM #2
Hi AJ,
A lot of three phase motors do get quite hot as does single phase ones ! If you look on the rating plate you will probably find a temperature rating or motor class rating. This will tell you what its temperature rating is. Some plates just give a temperature.
Also most motors that require cooling have a fan attached to the rotor shaft and a curved housing that directs air over the motor body. Some more modern motors intended for VFD use often have a fan with a separately driven motor that runs continuously to ensure cooling when the motor is being run at low speeds.
Fitting a fan may be helpful as long as it isn't fighting the air flow from the motor fan. Like in an enclosed space where you are just circulating a volume of air.Best Regards:
20th Apr 2020, 07:42 PM #3Member: Blue and white apron brigade
Not for a motor but for two VFDs I added a small fan to the box in the cabinet on my Hercus0 mill like this.
https://metalworkforums.com/f189/t20...-2#post1935493
Now that I've done it the fan is unnecessary - probably could have got away with just a vent but it would be different for a motor.
21st Apr 2020, 03:00 PM #4New Member
- Sep 2010
- Venus Bay Vic
- 6
I've been running my Craftsman for over thirty years and never had any overheating problems. When I got it I did convert it to single phase, I would have thought there is enough ventilation in the cabinet to avoid any heat issues.
Noel
Another Craftsman
By anj909 in forum THE HERCUS AREAReplies: 9Last Post: 8th Feb 2015, 07:20 PM -
Hercus Craftsman Spindle Help!
By anj909 in forum THE HERCUS AREAReplies: 2Last Post: 3rd Feb 2015, 07:54 PM -
The Re-Birth of a Craftsman or two
By Ray39 in forum THE HERCUS AREAReplies: 13Last Post: 16th Oct 2014, 01:42 PM -
Craftsman photos
By BlueSky51 in forum THE HERCUS AREAReplies: 3Last Post: 31st Aug 2014, 07:04 PM -
hercus craftsman?
By gallegos in forum THE HERCUS AREAReplies: 4Last Post: 10th Mar 2011, 09:23 AM
